Clunking noise front end C32
C32 2002
Hey guys,
I am hearing a clunking noise in the front end of the car on Occaisons when I brake harsh and also when I brak and turn the wheel to thr right. Anyone else also have this issue before? Suggestions? Help.
but you don't hear it when you shut the door? I had this problem a while back and i looked everywhere for it. I eventually found that a piece inside the fog light had come loose and fallen off inside the lens. I still haven't figured out how to get it out... i will though.
Something Slow
try this thread read from page 6
https://mbworld.org/forums/showthrea...=100665&page=5
i had some clucking noise too... it end up being the Steering Rack.
I am having the same issue... In my case it's the lower fornt passenger control arm. I still did not replace it. I called up the dealer and he told me $400 for the part (comes with bushings) I notice my issue when I am driving slow and pump the brake or when making turns into my driveway. But first I would have the bushings checked out, it's cheaper.
ive had all of the above things replaced by warranty. problem was not fixed until dealership replaced my motor and tranny mounts. not saying that is the problem, but if the above does not solve your problem, get the motor/tranny mounts looked at
