ECU Upgrade Rather Than Pulley's
1 Post
2003 C32 AMG, 2003 E39 M5
Could I get your guys feedback here? Especially ones that have used this Co tuning www.VelocePerformance.com. From reading posts from a member of this Co this guys REALLY knows his stuff. So the feedback I am looking for is someone who has just done what I described below and the results they had. What I am trying to accomplish is a way to get the most HP I can in the safest manner. The car still has 2-year warranty so the only thing I thought with the pulleys is they can just be removed before I go in for service. That is not so easy to do once you have changed your ECU. Although they did say you could send it back and have the stock file re loaded. If I can get another 30 HP out of the car for around $800 bucks that seems like a great investment. I am open to all thoughts and ideas
This is what the ECU Reprogram will provide:
Just re programming the ECU with this Co will net between 25-35hp/30lb ft torque.
It will also improve the drivability of the car by improving throttle response, and broadening the power band. Limiter can be removed.
2005 E55 ///AMG
Not sure you will get that much of a benefit on that particular AMG. I know the E55 can get 35-40HP and the 65 gets about 90HP.
Look here as this company is top notch: http://www.powerchipgroup.com/intera...sheets_one.asp
Aaron at StealthAuto (A Vendor on these boards) is a representative of this company and can help you with any questions. He is top notch to work with.
Take a look at the W211 section as this company has been the discussion of MUCH debate with their claims. From my own knowledge, I would HIGHLY doubt getting 30 more HP from a flash, and several other WELL respected posters " On both sites" have came to that same conclusion
See yeah
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2008 A8L, 2002 996TT X50, 2009 X5
Most who've modded and dyno'ed step by step to improve the knowledge base of the forum have seemed to suggest that upgrading the crankshaft pulley is the best, sure-fire performance gain for the C32 & SLK32. From there, you may opt to have an ECU tune to match the increased PSI you'd be running, or upgrade the cooling with a larger HE. After that, higher-flowing headers would likely be the next major step for performance.
Upgrades like wires, plugs, SL55 splitter, etc. are debated quite a bit as to if they provide any appreciable gains consistently, vehicle to vehicle. Air filters too... although C32used did extensive testing with his own car and the results suggested K&N and Green are indeed better than OEM. YMMV.
Till now, i haven't seen a single dyno chart before/after from Veloce. 25-35 hp from ECU reprogramming? I don't think the AMG engineers are that
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
1 Post
Looks like the pulley upgrade for me then. How many PSI's does it bump up when changing the pulley. I just have not had time to reseach what stock PSI is and then what it is when you add a different pulley.
Beside fuel economy are there any down falls to just doing the pulley and leaving the ECU alone?
Thanks guys I appreciate this
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Thanks guys I appreciate this![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Adam
from reading seeveral threads pulleys is best choice. If all gets done timely I will have ASP pulleys installed by tomorrrow and dyno on Friday and track results on Sat so wait. But dyno your car prior while stock.
[QUOTE= Are you running your stock ECU with the pulleys?[/QUOTE]
Yes I am using stock ECU. But even though I was told by several people I don't need to tune I was also told by a Tuner "yes.....I will eventually" to get full potencial of the pulleys. So I plan to run it all winter with pullies and maybe tune and dyno in the spring/summer.
P.S. I will redyno with stock ECU prior to tune in the spring/summer to see if the warmer weather affects my prior results first for the cold weather dyno with ASP pullies and stock dyno.
1 Post
Anyone have a comparsion of different pulleys. When I make the purchase I am more looking at quaility rather than cost. From being new here I have seen the following pulleys mentioned a lot renntech, ASP, Kleeman and Evo Sport. Are any of these better quaility than others? Or is it personal perference.
Before I got the car someone said the safest and best quality pulley and tune would come from Renntech since they are kind of partners with MB. I have no idea of the validity of this statement just passing on what I heard.
Who did you purchase your ASP pulley through? Cost?
1 Post
Thanks so I just need 2 pulleys and a belt it sounds like. Then the ECU tune will just help with the fuel consumption. I would think if I buy a set of used pulleys I just need to find a tuner that will tune my ECU to that specific brand pulley set up.
I say those are the top 3 used but the R and the K are very obvious when you open the hood while the ASP look vertally like stock but bigger. So you might get away taking it in for service at MB. I think alot is personal prefference but my reasoning to chose A was mostly that it appears close to stock and it give a little piece of mind when servicing car at stealership for warranty work. As for price I bought it used so got a great deal from another member. I say post for all three mainly used pulleys and people will show up with offers to you. They did for me....and I only listed A not the others.
Well the ASP set is actually suppose to be the Crank,Idler and Waterpump pulleys but I picked up the Crank and Waterpump with a belt and talked to a ASP rep first and the belt since smaller is the same as the 3rd pulley. A new set is about 1k and a good custom tune can be from $350-1k so $1350-2k out the door while R and K systems are in the 3k+range
2005 E55 ///AMG
You may also want to consider www.letmotorsports.com - a few forum members are running their upgraded pulley with success.
Also, don't you need additional cooling for the ASP pulley upgrade? Or do you need the additional cooling for any pulley upgrade?
Thanks!
1 Post
The co's I have spoke to about the pulley ECU upgrade have mentioned nothing about more cooling needed. But that is a good question since you are producing more boost
E55s seem to still have a lot of choices to make big power - Renntech being at the top of the list, IMHO... but you certainly pay a boatload for it.
As for cooling - at least with the C32, you don't NEED additional cooling with an upgraded pulley kit, but it's not a bad idea. Most seem to address this with an upgraded (i.e. larger) front-mount heat exchanger and perhaps an upgraded IC pump, and perhaps an additional coolant reservoir, etc etc. Search this forum for "larger heat exchanger" or "upgraded heat exchanger" or some equivalent, and you'll get a few good threads I'm sure.
Yeah, I purchased a pully AND the HE from Code3. I track my car so I KNOW heat WILL be a BIG issue. I would HIGHLY recomend BOTH together. Since Code3 came along, its CHEAP, EASY, AND BOLT ON, so the obvious question is why the heck not? Anytime you buid more boost, you get more heat, PV=NRT, sorry its the engineer in me. So get them both and rip her loose
See yeah
1 Post
Thanks that makes sense. Why add more HP and not be able to use it when it gets hot out.
Hey bud4ya:
Yeah, I purchased a pully AND the HE from Code3. I track my car so I KNOW heat WILL be a BIG issue. I would HIGHLY recomend BOTH together. Since Code3 came along, its CHEAP, EASY, AND BOLT ON, so the obvious question is why the heck not? Anytime you buid more boost, you get more heat, PV=NRT, sorry its the engineer in me. So get them both and rip her loose![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
See yeah![drive](https://mbworld.org/forums/images/smilies/driving.gif)
See yeah
no cooling required but if you are in hotter climate then larger ic and maybe phenomic spacer would be a good idea. these help to maintain your hp longer while system is hot.
