HIGH WINDING NOICE from oil fill/oil filter?????
Old Nov 7, 2007 | 10:57 AM
edtv82's Avatar
From: dayton ohio hopefully it will be some place warm and sunny when i finish med school
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
does anyone else get a HIGH winding noise in the mornings? on they're C32's? noticed that it was coming from (or at least seemed as if it was) the oil filter cap or oil fill cap.... at first i thought it was my power steering fluid chamber b/c i have Lucus' P/S fluid which is really thick... but it goes away after the car warms up... i changed my S/C bearing lastnight... b/c i originally thought it was the bearing making the noise(which the car idles smoother and no Knocking/clicking noise anymore thanks for the those who helped with my questions ) but since i think the noise is coming from something Engine OIL related... is there any kind of Engine Additive(s) that will stop the oil from getting heavy when its cold? but still wont burn off too fast when its warm? (im sure there isn't) or could i be using too thick of an oil during the cold months? 0w40 like the MB manual states... should i go with something like a 5w30, 10w30? i know from my EVO when i used Royal purple's heavier weight oils in the winter it kind of made a simular noise but was more rough sounding b/c the engine was struggling with the thicker oil which took 30minutes to warm up...
Old Nov 7, 2007 | 11:10 AM
edtv82's Avatar
sorry long post
Old Nov 7, 2007 | 11:17 AM
flush's Avatar
2003 C32
had this same problem - the whining noise is extremely surprising, sounds like it's going to blow up..... and once the car is warm, it goes away. happens when it's cold, right? especially now since it's late fall / winter.
dropped it off at the dealer, had them keep it overnight, good thing outside temp dropped to the low 40s, they started the car and heard it clearly - power steering pump issue, it cracked and leaked fluid, so the noise is due to low fluid, replaced everything. ~$300, not covered under warranty it seems.
Old Nov 7, 2007 | 11:35 AM
edtv82's Avatar
yep exactly what happens... hmm? the power steering housing fluid chamber cracked?
yeah i guess i could see that... i did notice a small leak in my parking spot at work... but i thought i was from another car... ( ha ha b/c i drove a MB go figure).... do you have the slip on what kind of equipment they replaced?
Old Nov 7, 2007 | 12:03 PM
edtv82's Avatar
OR A PART # WOULD BE HELP FULL AS WELL b/c im thinking i'll just buy the part and replace it myself..
Old Nov 7, 2007 | 02:26 PM
SRT6's Avatar
srt 6 chrysler crossfire
hmm I dont think you ment to spell noise with a C
Old Nov 7, 2007 | 04:58 PM
flush's Avatar
2003 C32
i'll check the invoice/worksheet report when i get home
Old Nov 7, 2007 | 06:07 PM
Eurocharged Rick's Avatar
SPONSOR
mine was doing the same thing...it was the power steering pump, it was a little low on fluid...i bet yours does it because of the thicker fluid you are trying to run through the system...
change your fluid and i bet it goes away...
Old Nov 7, 2007 | 08:25 PM
flush's Avatar
2003 C32
my invoice states:
P/S FLUID RESERVOIR FAULTY
1x GASKET 000-466-18-80 $3.83
1x OIL TANK 000-460-01-83 $38.78
1x HYDRAULIC OIL Q-1-32-0001 $28.20
P/S FUNCTION TEST FOUND NOISE WAS FROM P/S RESERVOIR. REPLACED P/S FLUID RESERVOIR. TOPPED OFF FLUID.
Old Nov 7, 2007 | 10:19 PM
edtv82's Avatar
was at work and heard my boss coming...
Old Nov 7, 2007 | 10:21 PM
edtv82's Avatar
my invoice states:
im guessing the "oil tank" is the same as the P/S reservoir?
Old Nov 8, 2007 | 11:40 AM
edtv82's Avatar
thanks for the part #'s ordered today from http://oempartsdirect.com/
total + shipping MADE IT $34.66 but thats not including my time but thats always free
