11 sec NA c55?
11 sec NA c55?
just wondering if a c55 could ever pull a 12 or just under sec 1/4 mile staying NA? with a recent guy pulling a 12.2 with bolt on renntech mods it may seem possible?
If CAP55 can run a 12.2 with those mods i think it may be possible. Throw in an lsd, an exhaust if he doesnt already one, and lose some weight. Might just be able to pull it off.
heres a link to the post about the 12 sec c55
https://mbworld.org/forums/c32-amg-c55-amg-w203/218198-new-c55-record.html
11's with some drags.
it may happen but it will take a combo of things, we are working on some things now....an 11.9x will take bit more HP right now and just cams wont cut it that I can tell you.
we are looking at cams now but the ones we are pondering are in the experimental stages. Possibly different header designs and dialed in ECU tune. May throw the towel in and go forced induction but not sure yet.
I have reentech ecu,airbox, kleemann headers with complete custom made exhuast, Ams crankpulley, evosport pulleys, & a 50 shot. The only problem is that I am running with some replica brabus wheels and regular street tires. These wheels are a bit heavy. With stock wheels and drags it should give some good numbers.
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Cams Did you Say Cams!
I'm Glad you looked into the cams. Victor @ VRP has co-developed a new profile set of cams , that so far has picked up over 20 more rwhp next the next best offering from the other major tuners. There is a Dyno sheet posted on the E-55 forums under VRP heads project. There is also a VRP cam Posting in The SL-55 forum. The specs will not be post as for they are proprietory. Cheers ___PTE___
