!!! LETMotorsports C32 Twin Turbo Project !!!
#451
SPONSOR
of course! i don't know how i missed you, i was there from beginning to end(first one there and last one to leave)...give me a call and we can set something up for you to come over and get the tuning done since you are local...
#453
c32, 190e 16v turbo
erick, dont mean to thread jack or get off the C32 topic but check this pic out of my turbo 16V she is back together and running ask Jerry what she sounds and looks like in person. I cant wait to get her on the dyno last time she was on did 392rwhp @16.8psi.. I did some upgrades so once properly tuned im shooting for around 500rwhp @ 21-22psi
#454
#455
2002 C32 AMG
Erick, good choice on going with the 16G set up. If it's still not enough, you can very easily upgrade since there are many variations and bolt in replacements for the 16G (Big16G, 20G, FP Green, FP Red).
Question: Where are you guys tapping the oil supply on the engine? Is there already an access point, or will you have to drill & tap?
#456
SPONSOR
that is why you need to purchase the kit from us...
#458
Do you have a site where we can see more pics or just email me
coolcarlski@yahoo.com
#459
Also if you can get a turbine cover for each turbine housing.
Those turbos as you know are used on DSM's and when folks buy them the first thing they do is port them to prevent the turbo also from spiking. They are very restrictive inside.
Dave Buschur at www.buschurracing.com can port them for you he is located in Ohio and knows those turbos like the back of his hand.
However it is coming along sweet I must tell you.
#460
Location: dayton ohio hopefully it will be some place warm and sunny when i finish med school
1 Post
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
Eric the guys right, those turbine housings do need to be ported or you can upgrade those turbine housings to 8cm turbine housings which would give you more power. Those on there are 7cm housings.
+1
#461
SPONSOR
once everything is up and running, it will not be hard to pull the turbos off and port them or swap to a 8cm housing...
thanks for the input guys...
#462
02 C32 AMG sold!
Having a bigger housing is needed when the turbo is undersized for the motor
/ chocking on the top end. Erick is using (2) of these turbos, so it should be
sufice. Dave may know standerized turbo but Erick is getting hands on trial
and error with this project. Whoever is intested in this project you are in
good hand with Erick's experience / knowledge.
#463
2008 A8L, 2002 996TT X50, 2009 X5
Based on what you're saying, you'd theoretically have to be at 615 rwhp to be maxing out two of these turbos. Assuming you might want to be at 80% of max for a safe cushion, that would be right at 500 rwhp, give or take. Exciting stuff mi amigo...
#465
trust me, i know, i used to have an Evo8, i am very famaliar with these turbos and what they are capable of, that is why i picked these particular turbos...Dave is a great guy and you are right, he knows his stuff, but i want to see how the car behaves with the turbos as is before i start porting and polishing everything...
#466
you will also need to see something, they are rated at 380hp for sure, but if thats with 4 cylinder -> 1 output , u are now using 3 cylinder -> 1 for easch turbo, u won't get 380hp out of it
#467
In this particular case, it'd be 1.6 liters per turbo - which is less than 1.8L 4 cylinder with one turbo ... so it might not be 380hp - which I guess is why I said "theoretically" in the first place - either way, this should be one fast beast of a C32
#469
#472
SPONSOR
DEMANDING, UHHHH?!
i guess you are entitled...
i am spending the whole day tomorrow working on the car, i will probably have some help for it as well, i will have some pics soon!
#473
