!!! LETMotorsports C32 Twin Turbo Project !!!
Rating: Thread Rating: 4 votes, 5.00 average.
Old 06-26-2008, 09:18 AM
  #476
BARRATT's Avatar
2002 Blue C32
HAHAHA! I feel soooo spoiled. Anytime I want an update I just drive 5 minutes to Ericks and check it out.
Old 06-26-2008, 10:12 AM
  #477
AirFrcd's Avatar
03 c32
OK. PLEEEEASE share with us
Old 06-26-2008, 10:55 AM
  #478
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
weak! and no updates / pics!!!!
Old 06-27-2008, 04:18 PM
  #479
KrzyFast's Avatar
SRT 6
...that's just not right!!! If you are there at least snap a pic or two and share with us...man that is just wrong...but it is really cool that you are that close and can stop in at any time.
I used to live in Houston for a while. It is certainly a fun place.
Cheers,
KrazyFast
Old 06-28-2008, 10:38 AM
  #480
AirFrcd's Avatar
03 c32
"patiently" waiting
Old 07-02-2008, 02:49 PM
  #481
c3232c's Avatar
02 c32 99 superduty
Any more teaser pics? Updates?
Old 07-02-2008, 03:19 PM
  #482
Dr. C36's Avatar
1996 C36 AMG
you know Erick,
You might want to consider a M104 turbo kit, those guys are dying for twin turbo kits (especially the C36 boys). If you could develope one for around $7-8k i think it would sell.
Old 07-07-2008, 06:18 PM
  #483
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Update? We're coming up on two weeks since the last one...
Old 07-16-2008, 06:20 PM
  #484
OJwerks's Avatar
not stock.
no updates on this ?
Old 07-18-2008, 03:47 PM
  #485
Kapium's Avatar
C32 AMG
Why not build a Synchro?
Hey guys, looks like you have a lot going on here, and I'd love to see what you come up with. I do have a suggestion though. Why not continue to use the charger, but feed it with the turbos. It seems to me like it would be an easier install, and be just as effective. The supercharger is a positive displacement pump, which is what gives the car such a flat power band, there is no relative change in boost across the rev range, but it does take power to turn the pump, in this case from the crank ~75HP at max RPM. The problem is that turbos aren't "free" energy either, they introduce pressure on the exhaust to turn them, which also robs power. The biggest factor in all of this is the adiabatic efficiency of the FI system. In this case we have one of the best superchargers ever constructed sitting on the top of the engine already. Why don't you add twin turbos to the motor each supplying about 8lbs of boost in parallel and force-feed the charger with them. Then under-drive the supercharger to about 12lbs. This will take less overhead from the charger at high revs, while supplying the smaller turbos exhaust from a ~5.5L equivalent (3.2L *1.8 atm) engine to spool them. That should make your 500HP while maintaining a nearly flat power band. This is what I intend to do to my wife's SRT-6 Crossfire when the warranty is up. My C32 stays stock, or close to it. Anyway, just my $.02. Nice work and carry on
Old 07-18-2008, 05:07 PM
  #486
AirFrcd's Avatar
03 c32
Kapium:
Great feedback.
I would love to hear Erick's response.
Old 07-18-2008, 08:56 PM
  #487
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
I believe this was discussed earlier in the thread and in a couple of other threads. This has been done before since WWII in fighter planes. For planes it worked out great, for a car it didn't have the same results.
VW did this a couple of years ago with a supercharger and turbo charger for there golf. The transistion between the two was horrible and generally hurt the performance of the car. Just look up VW GOLF GT.
Most modern ball bearing turbos can spoon pretty quickly anyways, long as there sized correctly for the car. Using both the supercharger and turbo adds a complexity to the kit that isn't really needed and cause problems in the future. A good tune can give a pretty flat torque curve anways.
I would rather just finish with the tt kit in a month then waste of a couple of months trying to get the two to work together reliably.
Old 07-18-2008, 09:04 PM
  #488
blackbenzz's Avatar
haters crazy
I agree with ^
Old 07-19-2008, 11:03 AM
  #489
Kapium's Avatar
C32 AMG
I'm aware of the VW, but I would not "transition" Many applications have seen this setup, with good results. I would simply feed the charger with the turbos. Since the supercharger will just step up whatever you give it, it will have the same torque curve shape it does now with the addition of a low - moderate boost turbo curve added on top. Also, this would likely get better fuel economy than the stock motor when you keep your foot out of it and should be easier to build because you don't have to remove / bypass existing hardware. Like I said before, just my $.02. I will likely do it in 2 years when my wife's car's warranty is up.
Old 07-19-2008, 10:52 PM
  #490
ericpd's Avatar
2003 C32 AMG & 2009 CTS-V
Originally Posted by ever12
Fraid not ThomASS.
Not anymore! Just saw on a "Supercar Exposed" program on Speed Network an owner somewhere in Miami has a 10 second C32! No info on what makes it go this fast (no shameless mention of any of the tuners I'm familiar with or what magic they used,.... guess whatever tuner(s) involved didn't pay the producers). The guy they featured also owned a Black, a DTM, and a brand new SL65. Of course the SL65 and the Ferrari obviously were the reason the show looked him up. Nice stable he had,... but particularly amusing was that there were no BMWs!
Anyway,... according to this program, somewhere in Florida resides a 10 second C32!
Old 07-19-2008, 11:42 PM
  #491
moosejaw's Avatar
none
I would be interested to see that
I'll keep my eyes and ears open and let you know
Old 07-20-2008, 07:29 AM
  #492
Newzchspy's Avatar
PLAID
Have a link or Timeslip???? I checked SpeedChannel and could not find anything and am assuming this is where it would be???
Old 07-20-2008, 10:25 AM
  #493
blackbenzz's Avatar
haters crazy
Hard to believe without some kind of proof
Old 07-20-2008, 10:50 AM
  #494
Newzchspy's Avatar
PLAID
+1
Old 07-20-2008, 09:23 PM
  #495
AirFrcd's Avatar
03 c32
Erick:
Any updates for us junkies?
Cclassy12 (03-17-2022)
Old 07-20-2008, 09:31 PM
  #496
C32AMGSC's Avatar
03 C32 AMG
Saw this thing in person this past weekend and it truly is a beast! Can't wait for this thing to get on the road bro.
Old 07-21-2008, 02:35 PM
  #497
360_iti's Avatar
W203, W211, W219, W212
a 10 sec C32 without a doubt has NOS
Old 07-21-2008, 07:40 PM
  #498
Eleventeen's Avatar
2002 C32 AMG
I'd also like to see a Whipple upgrade for these cars. Cheaper than twin turbo (probably) and fast as hell!
Old 07-21-2008, 07:42 PM
  #499
CLK FAN's Avatar
2000 CLK 3.2
When will this car be done?
I've been waiting patiently
Old 07-22-2008, 12:30 AM
  #500
OJwerks's Avatar
not stock.
I twin turbo kit in that beast of yours woudnt be all that bad
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: !!! LETMotorsports C32 Twin Turbo Project !!!
