!!! LETMotorsports C32 Twin Turbo Project !!!
Old Jan 6, 2009 | 09:01 PM
  #601
blackbenzz's Avatar
haters crazy
Originally Posted by e240TT
Oh
I need
1000rpm onwards in every 500rpm increment till 6000 ...
:P
Oops! I tried
Old Jan 8, 2009 | 09:56 AM
  #602
e240TT's Avatar
E 240
well
on dynojet, 200hp, 278nm and i called it a day, still messing around with various maf clamp because it still boost cut @ 5500rpm now.
original hp on dynojet is 150hp and 230nm
P/S : My ignition timing is still a -4degree :P , wait till i move it up, also boost @ 0.3bar, wait till i move it to 0.5~0.6 bar :P
Old Jan 8, 2009 | 11:02 AM
  #603
c32used's Avatar
LET C32 2002
Question
gains aren't bad...especially at that low boost....what type of car is it again I thought it was a C240 but your screen name confuses me. Sorry
Old Jan 8, 2009 | 12:33 PM
  #604
e240TT's Avatar
E 240
its a E240 :P
same engine as the C240 , M112 2.6L ME-2.8SFI
Old Jan 8, 2009 | 12:59 PM
  #605
msheredy's Avatar
MB
its a E240 :P
Oh wow, it's a 2.6 liter? Those numbers are really good so far!
Old Jan 8, 2009 | 01:09 PM
  #606
e240TT's Avatar
E 240
from the way it looks, i should get 300 engine horsepower, meaning bout 240 on the wheels.
just need to get the clamp right now.
Old Jan 15, 2009 | 12:04 PM
  #607
e240TT's Avatar
E 240
good news guys
i found the clamp voltages and i max'ed out my injectors as well
at 0.25 boost, turbo start spooling around 2000 rpm and full boost 3100rpm at 0.25 bar, 210hp/300nm now, after i drop the engine a 2nd time to block the exhaust valve that recirculate air into the intake manifold.
getting injectors now and pushing it up all the way to 0.5 bar.
Old Jan 15, 2009 | 01:08 PM
  #608
msheredy's Avatar
MB
good news guys
Awesome news! So by doubling the boost you should, in theory, double your horsepower gained from the addition of the turbo (hope that makes sense). How much would you say you gained from the turbo install?
Old Jan 15, 2009 | 09:09 PM
  #609
e240TT's Avatar
E 240
i would say about 50hp but 80~90nm .. with max'ed out injectors, i don't really know if this is the max i could go, i would say more. there is not enough fuel flow above 4500rpm ... it leanes out.
the turbo is sized correctly, and its a ball bearing, which spools and goes into full boost fast enough.
this 2 turbo can make 560hp at least @ 1.1~1.2bar, so by going 0.5~0.6, i would say 250hp ? maybe more ? but there would be load of torques
Old Jan 17, 2009 | 02:17 PM
  #610
OJwerks's Avatar
not stock.
common bro post full car pictures
Old Jan 17, 2009 | 07:41 PM
  #611
e240TT's Avatar
E 240
wait :P
even the dyno chart is not nice now as it leanes out above 4800~5000rpm
let me finish changing the injectors, pushing it more, then post a final dyno here, as for the car
its parked in the workshop for 1 year , nearly 1 year on this project ... so now its done, full of scratches, minor dents and so on, let me repaint it :P
Old Jan 19, 2009 | 01:10 PM
  #612
e240TT's Avatar
E 240
Dear Friends
Project completed, @ 0.6bar, 290hp, 388nm , i am so supprise in the torque, but here u guys go, i am running 0.43bar @ 43kpa now and this are the results
i will do another run with dynojet tommorow and bare in mind, this dyno has lower power then dynojet :P
using 260cc injectors now which i took out from a nissan fairlady 350z :P
duty cycle @ 90%
lowered hp due to stock internals, better be safe then sorry
Attached Thumbnails !!! LETMotorsports C32 Twin Turbo Project !!!-dsc00404.jpg
Old Jan 19, 2009 | 01:17 PM
  #613
msheredy's Avatar
MB
Good job!
Old Jan 19, 2009 | 01:34 PM
  #614
CLK FAN's Avatar
2000 CLK 3.2
Dear Friends
duty cycle @ 90%
congrats!
is this something you think can be done to a CLK320?
Old Jan 19, 2009 | 02:24 PM
  #615
e240TT's Avatar
E 240
if you have enough space to mount the turbo, i don't see why not.
Old Jan 19, 2009 | 05:14 PM
  #616
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
great numbers great job !!!
Dear Friends
duty cycle @ 90%
Old Jan 19, 2009 | 05:32 PM
  #617
TruTaing's Avatar
Moderator Alumni
w203 m112
Great job. Glad to see it come to completion.
Ya should create your own thread to summarize the whole process in a few posts so future readers dont have to go through 13+ pages to find all the info
Old Jan 20, 2009 | 01:27 AM
  #618
OJwerks's Avatar
not stock.
wow man awesome..... open up a new thread with full review ...details .. pics... and full car pics!! videoo
Old Jan 20, 2009 | 09:27 AM
  #619
e240TT's Avatar
E 240
i will try .. if i have time .. sorry .. too busy
Old Jan 23, 2009 | 08:09 PM
  #620
e240TT's Avatar
E 240
torque is too high for my gearbox hahaha ..
vadim is working on a 55's tq limiter remover/reprogram and may be able to help me on this.
Old Mar 3, 2009 | 05:40 AM
  #621
e240TT's Avatar
E 240
Updates..
0.6bar @ 60kpa @ 296rwhp , 413nm torque / 365engine horsepower , 490nm engine torque. gearbox is going to MKB germany for the 700nm torque upgrade and tcu reprogram unless of course, if i manage to find a c32 engine with gearbox, then its a different story.
what did i change to the engine for more power ? <-- there is a variable flap in the N/A intake manifold that open progressively as the rpm goes higher, i cut the flap off so now the flow can be better, earlier the turbo full boost at 3100rpm, now it does at 2200+-.
as for the engine, i am maintaining the 2.6l , crankshaft looks strong enough , Custom H-Beam Rods, forged piston with 9:1 compression, custom bearings and so on, i will also look for someone with the capability to tune the original ecu to remove rev limiters for me, i will be spinning the engine to 7000rpm now. as 2.6l has big bore and short stroke, the rev could be higher, custom head gasket will be made now.
Old Mar 3, 2009 | 02:30 PM
  #622
NitrogenBalance's Avatar
none
In other words are you saying you removed the EGR valve(exhaust gas return). I've wanted to do that to my M113 for some time now and TVT here even makes a block off plate for the M112/M113 EGR vavle. My concern is the ECU mapping and how it responds to just blocking it off....??
Old Mar 4, 2009 | 11:46 AM
  #623
e240TT's Avatar
E 240
i blocked that with a stainless steel plate and the ecu throw out a code, Exhaust gas recirculation flap malfunction, but no cel code.
i mean the variable flap in the intake manifold, if u take out the intake, u will see there is a flap, i cut the flap off so the engine is full time receiving full intake air
i also get a CEL error B28 Pressure sensor whenever my car goes into boost, after checking, there is a map sensor and that map sensor controls the opening of the variable flap, what i did is clamp the voltages, its 3.78volt at 100kpa above atmospheric level = i remap the voltages so it will not go above 3.85v and hence now the cel is gone.
I believe if i have a C32 Engine i may be making 500hp already with this 2 turbos, they are my own spec turbo, AR .64 rear housing, GT2530 front housing machined to hold GT2871R fins.
I need fellow friends help now, my car is a right hand drive E240, with the current power, it wheelspins whenever i floor the car suddenly. i need a LSD, and quaife don't know if they have applications for me .. Anyone can help me find out if any quaife application can fit my car ?
My vin numbers starts with WDB2110612Axxxxx if i am not mistaken. can't remember the last 5
Old Mar 4, 2009 | 01:07 PM
  #624
msheredy's Avatar
MB
That is very interesting that this worked out with positive results. That flap controls which runners, long or short, are being used. The longer ones are being used down low where you need torque [long intake runners increase engine torque]. When you are moving along pretty good that flap switches to the shorter runners to increase the top end horsepower [short runners increase top end power].
Interesting and great numbers BTW!!! Still waiting for your write up too!
Old Mar 4, 2009 | 01:26 PM
  #625
e240TT's Avatar
E 240
well i learned this from the kleemann supercharger kit where they removed the intake totally and just blow air in.
i will post new dyno graph, i was thinking if i get this engine's rev to 7000, it should make petty good power the 2.6l is big bore short stroke, hence the capability of higher rpm, from the dyno graph, the power still hasn't drop at highrpm. the only thing why it drops is cause i retard igniton timing and trim boost, as the gearbox can't take it.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
