Car eating Coolant up
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
My 03 C32 is eating coolant up fast. For the last 2 1/2 months I have used 2 full bottles of oem benz coolant. the coolant low light comes on after about 2 weeks and needs refilled. I checked for any coolant on the garage floor. I have looked for leaks and listened the best I could. I also filled up the resevior tank one day and accidently the little foil cover when you take the cap off the coolant bottle went right into the resevior and I couln't fish it out. Should I try a flush, or can the radiator be messed up. Please help with any ideas or suggestions.
Mechanic should be able to perform a 'leak down' test. they pressurize your
system, then watch gauge for signs of hairline fracture in head gasket...or
bigger leaks. once confirmed, they'll need to isolate source. has your exhaust
given you any indications of coolent ?
check the oil- see what that looks like. that's a good way to self test if a head gasket or intake gasket could be leaking. a leakdown test is the best way- but checking the oil is a good way to DIY.
Leaks
What should I look for with the exaust, and will the oil look bad if there is a gasket leak. Sorry guys I'm still a novice with most of this stuff.
exhaust would most likely have a smell to it- faint smell of coolant (in my opinion of cars i have seen this on in the past). it might also have a white'ish smoke.
the oil will look like it has some milky swirls in it- ranging from white'ish to faint green'ish. the oil would, depending on the level of coolant lost, register as being way overfilled and have bubbles in it.
a head gasket and intake gasket could have two different kinds of leaks. 1) external- you would see the coolant in the engine bay or on the floor. 2) internal- the coolants is either leaking into the air intake or cyclinders and being burned off (smoke/smell in exhaust) or leaking into the oil passages (contaminated oil).
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Your intercooler core is probably busted or cracked an leaking coolant into the intake runners. A common problem with C32s. If you do a search for intercooler core, low coolant etc you should find a lot of information about it as well as pictures................
02 C32 AMG sold!
Could have a air pocket in the cooling system, run the car w/the reservoir
cap off, and see if it goes down, if it does fill it to full and cap it off while
the car is running.
the car is running.
Here is a thread with some good info on this:
https://mbworld.org/forums/showthrea...tercooler+core
Audi C7.5 S6
Most likely intercooler core, which lists for about $1900. Mine was replaced for leaking at around 39k miles. Need to remove the supercharger to replace, since it is mounted on the underside of the blower.
Pull off one of the intake surge tanks, look inside the ports, you will see crusty burnt coolant on the inside.
Leaking that much coolant it must be the intercooler.
Only a very small of coolant from the radiator to the transmission would goof up the shifting.
it is either the intercooler core leaking or a bad Valeo radiator that is leaking coolant into the transmission...either way get it checked asap! don't drive the car anymore because if it is the transmission, you can kiss it goodbye if you continue to drive it...
Cars and boats!
If your car is under warantee take it in... save your mechanic some trouble and tell him its time to replace the supercharger. Correct me if I'm wrong but I dont htink they sell the heat exchanger peice under the s/c by itself. The heat exchanger under the supercharger is most likely where the leak is. I've seen this on several C32s in Miami.
S600TT, R350
Evan, I hate to say, but it does sound like an intercooler. The only way to fix it is to replace it. Mine went before and I tried to patch it, weld it and even epoxy it. Still leaked.
If you want to bring it by, I can tell right away by simply removing one of the surge tanks.
