19" wheels on c32 amg
2002 c32 AMG 2012 c250 Coupe
i recently purchased 19" EXE KONVEX wheels for my c32. they are the staggered fitment, 19x8.5 in the front (clearing the AMG calipers) and 19x9.5 in the rear. but i encountered a problem, their was this loud clicking noise coming from the rear wheels when i started driving. so i parked it. does anyone know what it might be..? will i need spacers..?
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
sounds like you need shorter wheel lugs(bolts). dismount the wheel and compare how much lug thread protudes from back of wheel face for stock vs the new wheel. when the wheel is off look into the lug holes you may see scoring inside where the lugs were making contact.
Whamtrini (11-02-2023)
your rear offset should be around 35mm. also check that the wheel spokes aren't touching the caliper..........but bolts are the most likely culprit.
i had to grind off some of the rear caliper in order to clear the wheel but ill check the lug nuts and see what the difference is between the stock and new ones.. thanks for the info. im new here and i see that this is really helpfull so hopefully later i can help someone else like how you guys are helping me out.
where can i find shorter lug bolts..? would i be able to get them @ the mercedes dealer..? can it be fixed by adding wheel spacers..?
MBworld Guru
white and whiter
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
when are ppl going to realize don't buy from ebay unless you know what you are into.
2004 C32 ///AMG
you could fix it by adding spacers, but be very careful and check the offsets...it'll probably rub if they stick out more.
C32 AMG
I'm having the same problem, but it's intermittent - which is really driving me crazy. Some times I hear the clear ticking, sometimes nothing. And I am talking about low speeds (less that 10MPH). I am aware that at high speeds you can't hear anything. Does this make sense?
Grind off cailpers wow... never heard of this one b4. Should check for the correct offset before purchasing
. 37mm front 32mm rear stock c32 offset, 35mm also fit the C32 front and rear. I Have 19's with no issues whatsoever.
ur just too fast too furious there cowboy..!!! i got the wheels from streetdreams.org. these wheels were ordered for a 2002 c240 i had but i got rid of it and bought a 2002 c32. no they wornt bought off ebay.
good news guys, we fixed the problem. it was what AWDman and RLEE02135 said about the lug nuts hitting the parking brake indside the rotors cus they were too long. THANKS AGAIN FOR YOUR EXPERTISE..! DKFLIPSE you might have the same problem. you should look into it.
MBworld Guru
white and whiter
depends on the wheel
best fitment for 8.5 width on the front is 28-31 offset.
best fitment for 9.5 width on the rear is 35-38 offset.
stock offset is for a 7.5 width rim on the front and 8.5 rim on the rear.
MBworld Guru
white and whiter
you should never grind the caliper to make wheels fit. the stock caliper are not high strength forged steel.
Am I correct in assuming that fitment you quoted above for 8.5/9.5 F/R would be the same for the C55?
C32 AMG
Not a Good Picture
OK. For anybody out there that was wondering. When you hear the little clicking noise mentioned in this thread - do not ignore it!
Notice closely and you will see that the rim is completely off the hub!!!!![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
The rotor is sitting on the inside of the wheel.
The lug nuts are snapped!!
Luckily I was only going 5MPH, cuz I take the turnpike to work daily and do 70 or so. Got the car towed and the rim is OK except for cosmetic damage. But the vendor is replacing it free of charge.
MBworld Guru
white and whiter
a quarter mile at a time
