stearing column is broken
ing wheel but not up or down. Can anyone please shed some light into this.
Here is the info from my service ticket:
Steering Wheel Inoperable - Stuck and will not go up/down
Cause: 46295067
467704 Steering Column with Shaft - Electric Adjustable, R & R
26 WMBS
467741 Adjustable Steering Column W. Shaft, D & A / Repl. Parts (Column with shaft removed)
26 WMBS
1 203-462-06-78 Coupling Col
I think 1 203-462-06-78 is the part number for the coupling that needed replacement.
Since my C32 was still under warranty the repairs did not cost anything.
My Dealership charged me $540 Labor, and $4.31 for the part... Lucky for me I had extended warranty. But does this seem high? Is it really that much labor..??
Mine is an E55, but Same part# listed above. Found this thread through google / part number..
thanks guys
Think you can be a little bit more specific as to reaching up and removing the broken part? Perhaps pics?
Thanks,
I have 2005 c240, and I has the same troubles(the tilt steering wheel halt "up & down").
Today I brought back from the dealer.....the total repair cost was $1051.01(a part, the labor, etc).
A part was 203-462-06-78 A Coupling Col($9.03)
Labor was $946.53(7 & 1/2 hours).....$125 per hour in Kailua-Kona, Hawaii.
Pay Shop Charge For Repair Order was $27.88
I believe that the part is not high at all.....the labor is very expensive!
But at least they fixed it and I feel good about.
Can anyone please share clear instructions for removing the parts for accessing this gear / "coupling column". I am interested in what to remove and how to remove it.
About Nick's and AMGC's comments: Can you please describe when you reach in (without opening all the other parts), a few things such as:
. how far do you have to go from the opening before reaching this part,
. which side of the steering column to feel for it,
. once you have grabbed it how do you remove it (i.e. pulling it straight
out, or vertically, or squeezing from the two ends, or bending from the
middle, ...),
. whether to worry about "knocking" some other component out of position
while trying to pull out / install this coupling column
. etc.
Even 2-3 pictures would help much too, particularly of where to reach in from, pointing to the approx location of this part (from behind the steering column cover), ...
If you would care, any one w/ any info please PM me too.
Thank You,
