Kleemann ECU 8-10% hp gain True? false?
Old Mar 19, 2008 | 12:57 AM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
Kleemann's website says I can expect an 8-10% gain in HP with there ECU? so at the flywheel i would be making on the low end of that 390hp in my C55? is that true or are the gains not near 8-10% If its true... for a benz that's good bang for your buck at around $1000.
Old Mar 19, 2008 | 06:25 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Check around my friend, I haven't seen ANYONE get a gain on a N/A motor from a tune that high. You may get 10-15 HP, But I beleive from posts on this board, that You will NOT get 35-40. Sorry for the bad news.
See yeah
Old Mar 19, 2008 | 07:56 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Kleemann Tune.
I did their ECU tune several years ago. It did very close to what they Claim. I went from 295RWHP to 306 RWHP. I posted the Dyno sheet a while back. What really impressed me was the midrpm band torque increase. It was like 26 RW Ft,Lbs. The driveability, Trans shift points, Throttle response, was Dramaticly better. Their tune does more than just Hp increase. If need be after I get back from Graz , Austria . I post the old dyno sheet, It May be still here if you do a search, under posts started by ___PTE___ Cheers ___PTEngineering
Old Mar 19, 2008 | 08:56 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Hey there PTE:
You know your post just said why I said. You gained only 9RWHP, which is about 12 at the crank which is about a 4% improvement
Oh well, glad to hear you like it
See yeah
Old Mar 19, 2008 | 09:28 AM
PTE's Avatar
PTE
My Post
They kinda don't tell where the increase is at , bUT was well over the 8% in the midrange. sometimes it is more than, just a big top end number. That's why I went into the improved drivability thing. Dyno doesn't show well for me. The track & street said it all . All said & done with my modds the car still runs a 12.66 et & 111 mph on a pee poor track at Moroso WPB.
Old Mar 21, 2008 | 01:40 AM
c32used's Avatar
LET C32 2002
See yeah
+1
READ IT AND WEEP...
Old Mar 21, 2008 | 06:27 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
9 whp for $1000 seems pretty expensive to me. You should probably max out on the breather mods first before the tune. The tune will benefit you more if you already headers, intake and exhaust installed first.
Old Mar 21, 2008 | 11:43 AM
c32used's Avatar
LET C32 2002
Unfotunately thats about right.
Old Mar 22, 2008 | 03:57 PM
PTE's Avatar
PTE
I like it like this
One thing about a Kleemann tune , I only brought it once .And I did many changes , and installs of Kleemann Mods , one at a time, no less. The accompaning ecu update came free of Charge. I only paid for it once
Old Mar 22, 2008 | 04:21 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
What Kleemann Mods do you have?
Old Mar 22, 2008 | 06:49 PM
c32used's Avatar
LET C32 2002
Exclamation
Guys do a dyno prior to then after. Cause what websites claim is best tested results. Our engines are handbuilt so hp/tq numbers vary in each car as I heard. The biggest boost for S/Ced cars is a bigger pulley....
