weird chirp like noise when stopping or taking off.
Subscribe
Mar 24, 2008 | 01:02 AM
Ok, I know this is gonna be vague... but I have to ask. Whenever I am coming to a stop, and when I am taking off from one... I get a strange "weh" type noise. I am usually good at isolating stuff like this, but this has me completely thrown. But I really think its coming from under the hood. Any ideas? Sorry if this is so vague, but I am hoping another owner has run into it.
Reply 0
Mar 24, 2008 | 09:14 AM
Quote: Ok, I know this is gonna be vague... but I have to ask. Whenever I am coming to a stop, and when I am taking off from one... I get a strange "weh" type noise. I am usually good at isolating stuff like this, but this has me completely thrown. But I really think its coming from under the hood. Any ideas? Sorry if this is so vague, but I am hoping another owner has run into it.
Sound/Video clip is going to be ideal. I have a sound from time to time when it's SUPER cold out that eventually goes away. But off the top of my head, I can't make "weh" sound like a chirp
Reply 0
Mar 24, 2008 | 11:17 AM
Probably the Kompressor clutch going bad.
Reply 0
Mar 24, 2008 | 02:17 PM
This thread explains something similar. Is this close to what you are experiencing?
https://mbworld.org/forums/c32-amg-c55-amg-w203/225947-jerk-chirp-saga.html
Splinter took a drive in my car and did not notice it as much as I did. Of course, it's never a good idea to have a mostly deaf person listening for a chirp in your car. His car made the same noise. We both believe it is the S/C clutch.
Reply 0
Mar 24, 2008 | 06:52 PM
Thank you everyone! And thanks for the link. I believe its definitely the same issue as mine. I gotta bring the car in for this... again. Hopefully they can clarify if in fact it is an issue or not. I will push the issue, and see if anything comes of it. Thanks guys!
Reply 0
Mar 24, 2008 | 09:28 PM
Quote: ...splinter took a drive in my car and did not notice it as much as I did. Of course, it's never a good idea to have a mostly deaf person listening for a chirp in your car...
WHAT?!
I’m only partially, okay, three-quarters hard of hearing and oblivious to the joyous sounds' of the world around me. The voices in my head come through loud and clear, though.
pointman- hope you get yours squared away. Kindly keep us updated.
Reply 0
Mar 25, 2008 | 01:29 PM
That must be why you waited so long to do the resonator delete. Sounds the same to you either way?
Pointman, I just did the ECU reset the other day and it did relieve the chirp (a little) until the ECU re-trained itself.
Reply 0
Mar 25, 2008 | 05:38 PM
Are you sure that your water pump is not going kaput? Is the chirp coming from the belt? That's what happened to me. I used to get a slight chirp when the car was idling but was not consistent. It pissed me off because I replaced the SC last year due to the SC clutch. I opened up the hood while the car was running and found the water pump pulley wobbling which is a sign of the water pump going bad. After the pump and belt replacement, no issues.
Someone else mentioned if you could post a sound clip it could help us out a lil better.
Reply 0
Explore
Mar 28, 2008 | 07:24 PM
Quote: That must be why you waited so long to do the resonator delete. Sounds the same to you either way?
Hmm, interesting. Will check with the dealer as a possible solution. Thanks.
Reply 0
Mar 28, 2008 | 07:25 PM
Quote: Are you sure that your water pump is not going kaput? Is the chirp coming from the belt? That's what happened to me. I used to get a slight chirp when the car was idling but was not consistent. It pissed me off because I replaced the SC last year due to the SC clutch. I opened up the hood while the car was running and found the water pump pulley wobbling which is a sign of the water pump going bad. After the pump and belt replacement, no issues.
Hi, thanks for the suggestion. Its weird cause I get it right as I stop, and right as I take off. Not sure if there is any wobble or not. Will try to get a sound clip. Either way, will report back. Thanks for the help!
Reply 0
Mar 28, 2008 | 07:57 PM
What year and model do you have?
Reply 0
Mar 29, 2008 | 09:12 AM
Quote: Hmm, interesting. Will check with the dealer as a possible solution. Thanks.
Pointman, the ECU reset I was referring to is the 4 step process you do in 2 minutes, 5 seconds in your own driveway. You probably remember reading about it in this forum. You know, with engine off, turn key to 2nd ignition position, depress gas pedal to floor for 5 seconds, turn key off then remove foot from gas pedal, wait 2 minutes and go.
Your car will feel brand new again. I do this all the time and love the fresh feel of the car afterwards.
Reply 0
Mar 29, 2008 | 03:37 PM
Quote: Pointman, the ECU reset I was referring to is the 4 step process you do in 2 minutes, 5 seconds in your own driveway. You probably remember reading about it in this forum. You know, with engine off, turn key to 2nd ignition position, depress gas pedal to floor for 5 seconds, turn key off then remove foot from gas pedal, wait 2 minutes and go.
Yes sir. I am familiar. I did it once, and coincidentally got a CEL. Since then, I am scared to do it again. lol.
Reply 0
Subscribe
Currently Active Users (1)
