c55 Clear Side Marker Install
Subscribe
Apr 14, 2008 | 11:05 PM
Can anyone give me advice on popping out the OEM orange side markers. Is there any way to pull them off without removing the splash shield? Do they bolt in or just pop out? My clear lenses come tomorrow.
Thank you in advance,
Alex
Reply 0
Apr 14, 2008 | 11:55 PM
Just pull it out with your fingernail with a little force. If its too tight, find a flat object which will not damage your paint, tuck it in between marker and inpact strip then pull the marker out.
Reply 0
Apr 15, 2008 | 12:26 AM
Quote: Just pull it out with your fingernail with a little force. If its too tight, find a flat object which will not damage your paint, tuck it in between marker and inpact strip then pull the marker out.
+1
Reply 0
Apr 15, 2008 | 01:20 AM
Pull on the front or back?
Reply 0
Apr 15, 2008 | 01:28 AM
I usually pull the back out first (the fatter part)
Reply 0
Apr 15, 2008 | 04:41 PM
Thanks a ton. I will post pics when I'm done. I just put the flat MB emblem on the hood and it looks great
Reply 0
Apr 15, 2008 | 09:59 PM
I slide the marker all the way towards the back of the car and then pull the front with my fingernails. It has several mils of clearance and it should be enough to disengage the marker shoulder/keeper.
Good luck!!
Reply 0
Apr 15, 2008 | 10:16 PM
You can always to remove a side marker light the way I did 6 hours after I bought the C55, hit a bobcat (the feline kind) running across the road while doing 55 mph. You just have to ignore the $4k+ collateral damage.
Reply 0
Apr 15, 2008 | 10:28 PM
The "correct" way to do it is described in your owners manual. Front slide back, pop out. It may be tough to do it for the first time because it probably hasn't been popped out since new.
Reply 0
Apr 16, 2008 | 02:58 PM
Quote: The "correct" way to do it is described in your owners manual. Front slide back, pop out. It may be tough to do it for the first time because it probably hasn't been popped out since new.
Interesting...... never knew this kind of stuff is described in an owner's manual. Can you post what section and sub-section it was under? I wonder if my car's manual has similar instructions, as I've been thinking about clearing mine as well.
Reply 0
Apr 16, 2008 | 03:59 PM
Just found it in owner's manual under: Practical Hints- Replacing Bulbs- Side Marker Lamp.
Its page 350 on my maual
Reply 0
Apr 30, 2008 | 09:52 PM
Quote: Just found it in owner's manual under: Practical Hints- Replacing Bulbs- Side Marker Lamp.
Thanks guys. Page 350 worked like a charm for me to.
Reply 0
May 1, 2008 | 05:21 AM
colormatch lenses>clear lenses
Reply 0
May 1, 2008 | 05:34 AM
Quote: colormatch lenses>clear lenses
+1.
I saw a few smoked ones on Ebay tho.. dunno how those would look on our cars.
Reply 0
May 1, 2008 | 07:57 AM
These are ones I made back in 2005...On my C230
Jake
Reply 0
May 1, 2008 | 09:04 AM
Since I got my C32 in Jersey, I was forced to get it inspected in my home state of PA. I didn't even notice that I had color marked lenses until the shop told me they had to put in the regular side markers to pass. What a difference.
Reply 0
Subscribe
Currently Active Users (1)
