Loss of power, coolant pump already replaced.
Old Apr 19, 2008 | 02:04 PM
pointman's Avatar
a car that can't do the throttle reset.
I am having the same symptoms again... on highway, major loss of power. It comes and goes. I had the same issue several months ago, and it was solved by replacing the "Coolant Pump". Any ideas what the issue could be this time around??? Thanks.
Old Apr 19, 2008 | 02:11 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
If it was an OEM pump, then it's probably bad already.
Any codes?
Old Apr 19, 2008 | 02:21 PM
pointman's Avatar
Already bad again??? Can't be!!! Its only been a few months. No codes yet. Will report back from what dealer says.
Old Apr 19, 2008 | 02:40 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
you wouldnt be the first one to have the pump fail after a couple of months. The design just isnt up to par.
If it is do yourself a favor and get one of the Johnson pumps from LET.
Old Apr 19, 2008 | 02:59 PM
ChicagoX's Avatar
W211 E55
I had one fail on me in mere months. Jakpro1 sent me a low-mile pump that I disassembled, and it was on the way out as well - full of black toner-like powder !!!
No codes tells me it's most likely the pump. Get the CM030 pump, and you can tell everyone you're sporting the "big Johnson"
Old Apr 20, 2008 | 12:12 AM
BARRATT's Avatar
2002 Blue C32
+ eleventy billion
Old Apr 20, 2008 | 01:06 AM
pointman's Avatar
Better life expectancy?
Old Apr 20, 2008 | 01:07 AM
pointman's Avatar
Damn it. I hate that this is going out again. Thanks for the suggestion. Any chance you got a link where to buy? And DIY?
Old Apr 20, 2008 | 12:37 PM
edtv82's Avatar
From: dayton ohio hopefully it will be some place warm and sunny when i finish med school
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
Any codes?
i wouldn't say its bad... the C32 has a huge heat issue... that why there are some people on this community who have developed a bigger heat exchanger... to keep the c32 running at peak performance longer... but if your car gets hot... the SC wont kick on to protect the engine
Old Apr 20, 2008 | 12:40 PM
edtv82's Avatar
DIY thread: https://mbworld.org/forums/c32-amg-c55-amg-w203/206555-replacing-bosch-ic-pump-johnson-c030.html
link to purchase:
http://www.autoperformanceengineering.com/
http://www.letmotorsports.com/c32.as...2&category=all
Old Apr 20, 2008 | 01:03 PM
loungn14's Avatar
SPONSOR
Its actually a pretty simple diy, I got one from LET and had it completed within an hour
Old Apr 21, 2008 | 12:03 PM
pointman's Avatar
Thanks. Its weird cause I have had 20k miles of no issues, and now its starting to go *** up. Even in 100 degree weather never had any issues with the blower not turning on...
Old Apr 21, 2008 | 12:04 PM
pointman's Avatar
I love you, no homo.
Old Apr 21, 2008 | 12:05 PM
pointman's Avatar
Nice to know! Thanks. Hopefully I don't mess it up... which is a highly likely thing to happen.
