gear slipage - did anyone else had the problem??
Old Apr 21, 2008 | 02:17 PM
van001's Avatar
c55 amg
I was really scared for a bit..i was driving on the free way other day and when i accelerated the car to pass another car in front of me, the gear slipped..the engine kept reving but the gear won't shift. I had to pull off in the shoulder and restart the car..it was ok then. But i was really pissed off..i could have been in an accident. Taken an appt with dealer tomorrow..lets see what he says..BTW i felt terribly embarassed to pull a 2 year old AMG off the shoulder
Old Apr 21, 2008 | 02:46 PM
Fifth Ring's Avatar
C32 AMG
I've never heard of that problem occurring with a C55 or C32. I assume you have a warranty.
(And I thought only C32s has problems! )
Old Apr 21, 2008 | 02:50 PM
riseAMG's Avatar
C55 AMG
Maybe???
You might need a new trans, but they will do a diagnosis on your trans and if a fault code pops up, then they will try to see which gear it is slipping on, if its under warranty have them replace the trans. Again, a friend of mine had the same problem with his c55 and they replaced his transmission.
Old Apr 21, 2008 | 03:39 PM
spr's Avatar
spr
Post more info about this as I had this happen in 1st or 2nd when rolling slowly a couple of times. I want to address this with the dealer when I go in and have docs to support it as a KNOWN issue. Thanks
Old Apr 21, 2008 | 03:49 PM
dkflipse's Avatar
C32 AMG
Are you sure it's gear slippage or just the well documented IC pump failure? When mine was failing (intermittently) I would floor it and the car would not move. Engine would rev high but SC would not engage. You may think it's gear slippage - but I would check here first. GL
Old Apr 21, 2008 | 04:05 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Nice thought but....
Did you notice he is driving a C55?
Old Apr 21, 2008 | 04:29 PM
Fifth Ring's Avatar
C32 AMG
That's funny.
So, then his IC pump is definitely NOT working.
Old Apr 21, 2008 | 04:45 PM
dkflipse's Avatar
C32 AMG
Got me!
Old Apr 21, 2008 | 07:15 PM
frimmelnojerz's Avatar
2002 audi s4
possibly a torque converter issue? its all speculation until you get the codes check out by the dealer but i would never jump to the conclusion of a messed up transmission. that, my friend, is one expensive assumption.
Old Apr 21, 2008 | 07:28 PM
1qikctr's Avatar
Merc power
could be anything..... get back to us with your results !!! best of luck on it.
Old Apr 21, 2008 | 11:48 PM
c32used's Avatar
LET C32 2002
Old Apr 21, 2008 | 11:49 PM
c32used's Avatar
LET C32 2002
Originally Posted by Fifth Ring
That's funny.
Old Apr 22, 2008 | 01:00 AM
M_M's Avatar
M_M
C32 AMG
I experienced once, when the engine oil was overfilled.
Old Apr 22, 2008 | 08:04 AM
timberman's Avatar
silver 2002 c32 amg
have you checked for oil leaks from the gearbox ?.
A low oil can cause gear slippage and has happened to my C32 in the past
Old Apr 22, 2008 | 01:51 PM
van001's Avatar
c55 amg
I went to the dealer today and he says it's transmission control valve problem. It happened copule of times..once at the stop light , when i pressed the gas pedal, the engine reved but did not shift and couple of times on the freeway when i pressed the gas peddle hard to accelerate. I could not reproduce it today when i was in the shop but the technician noticed the jerk when it shifted from 2-3..It's under warranty so I don't have to worry but it's kida annoying to see the transmission problem in a car that costs so much..
Old Aug 21, 2008 | 06:31 PM
duncanp's Avatar
C32 AMG, ML 350, Toyota Hilux 4x4
I experienced the same problem yersterday. The dealership diagnosed it today and confirmed I need to replace the valve control or something like that.
My car is out of warranty so they advised they can take it out then I have to find a good gearbox mechanic. Is it a good idea and how complex is the C32 gearbox. Can any mechanic work on it?
Old Aug 21, 2008 | 06:41 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Nevermind- I see it's a C55....
Old Aug 21, 2008 | 06:44 PM
trbo2nr's Avatar
Not sure about the C55 but I had the dealer mention to me a part damage on the trans and said it could leak if not replaced. Whatever it was they replaced and it wasn't too expensive- maybe a seal or something.
