I am offering a set of 16 Bosch 37lb Fuel Injectors for $50 a piece. These will allow you run more boost and still have plenty of fuel supply.
These babies will really allow you to run with Code 3 SC pulley combined with the Crank Pulley by giving you more fuel when you need it.
The upcoming LET fuel injector offering are only 32lbs I believe.
your car is sick. what kind of 1/4 mile can it crank out? 0-60?
Quote:
Thanks for the props...I wasted alot of money with some bad choices like HPS but since then it's all good.Originally Posted by SeeKlasse
When Vadim @ VRP is done with this next round I could be in the mid-high 10's. 0-60 in the mid-low 3's.
Stock C55 injectors are 42lbs. These are 47lbs!
You'll need a custom ECU tune. If you're to the point where you need upgraded injectors, you'll know it. LET will be selling higher output injectors with an ECU map made specially for those size injectors. Going with something different would require custom dyno tuning (time & $$$).
SPONSOR
Quote:
exactly
AMGSC- please don't presume what size injectors we will be running, we haven't even posted any info as of yet...stock C32 injectors are 415cc injectors...
ExploreQuote:
My bad. I could have sworn I read that somewhere. So 415cc calculates to 39-40lb injectors?Originally Posted by 1FASTC32
exactly AMGSC- please don't presume what size injectors we will be running, we haven't even posted any info as of yet...stock C32 injectors are 415cc injectors...
