ignition coil part number??
Test it first
The coil for a C32 appears to be the same as any of the dual plug 112 / 113 engines. It's part number 0001587803. It has a dealer retail price of $185 and is available at many dealers for about $150 with the MBCA discount. It's about $120 at many aftermarket locations.
I don't know what you're fixing, but unless you are 100% sure a coil is bad, I would swap it with the same coil on the opposite cylinder head and see if the problem follows the coil. Most of the time, ignition problems are due to bad plugs or wires. IHTH
