We need C55 modified Air Tubes
Old Nov 17, 2009 | 01:57 PM
02C32guy's Avatar
2005 E55
Originally Posted by AMGSC
Here are some pics of the dual 3" intakes. They just need to be polished up.
Thoughts?
They look pretty sweet. Any chance they fit the C32?
Old Nov 17, 2009 | 02:22 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Originally Posted by 320 dreamer
you have the right idea with the dual cai. needswings has had these for a while now as had eurocharged. you need to get them in front of the radiator as the engine heat will pull power from the tubes. i also have ss tubes and they were reading 150+ on temps after a small run. go to any performance staore and get some black exhuast wrap. now i can lay my hands on them and temps are in the 70's with the cold air from the front of the car
So you wrapped the stainless steel tubes? Doesn't that take away from the look? I can't fit the cone filters in front of the radiator but the incoming air will be channeled to the cone filters with aluminum shields which will double as an engine heat shield.
Old Nov 17, 2009 | 02:23 PM
AMGSC's Avatar
Pretty sure they will fit the C32's but only FD would know exactly what changes would need to made to the kit he built for the C55's.
