AMS pulley install on Thursday
Old Jun 11, 2008 | 07:39 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
My AMS pulley will be here Thursday morning and installed same day. this time i will have same day before and after dyno's as the weather conditions in Arizona have changed. I will be sure to post any gains i make. look for results in the late afternoon. Big thanks to the Guys at LET for the fast service and the good price.
Old Jun 11, 2008 | 08:00 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Good stuff! Let us know....
Old Jun 12, 2008 | 01:57 AM
Eurocharged Rick's Avatar
SPONSOR
anytime!
Old Jun 12, 2008 | 11:14 AM
Biscuit's Avatar
'03 C32, '08 ML63
I'm looking forward to seeing the results on this, Hooleyboy. Even though you've got a 55 and I'm driving a 32 I'm really enjoying watching your threads in your quest for more power.
Old Jun 12, 2008 | 11:51 AM
Dr. C36's Avatar
1996 C36 AMG
Keep in mind it does take about 1 week for the ECU to adapt to lightweight crank pulleys simply b/c things are happening quicker than the ECU is normally used to, so doing back to back same day results won't necessarily tell you the whole story. You can help out this process by doing ECU reset and driving it aggressively for alittle bit, but usually full adaption takes about a week.
Old Jun 12, 2008 | 11:55 AM
hooleyboy's Avatar
C55,SL55,C63
Im waiting for fedex to drop it off as we speak. then its to the shop for install. I hear i might need a new crank bolt from reading other posts. I got a bunch of mods to this car and i hear that helps with getting gains I really don't know what to expect with this mod. I will give a full review for you all as this seems to be a more budget friendly mod people will do.
Old Jun 12, 2008 | 02:53 PM
Dr. C36's Avatar
1996 C36 AMG
For C55 you do not have to update bolt. Only on the older E55s & C43s do you have to update it, the previous crank bolt design sucked. your C55 already has the new bolt (#006 990 70 04) from the factory.
Check your MPGs now, I'd like to hear difference in MPG both city & hwy and at steady mph. should be interesting to hear your results.
Old Jun 12, 2008 | 03:00 PM
c32used's Avatar
LET C32 2002
Wow! at this rate you will be up there in power with the big boys
Old Jun 12, 2008 | 03:45 PM
FishtailnZ's Avatar
Looking for a new toy.
I'd defintely go with a new crank bolt - I was told it's a "stretch to yield" type bolt and shouldn't be reused.
Thanks for all the work though you're putting into documenting all these mods, it's a great source of info for the whole community here!
Old Jun 16, 2008 | 12:16 AM
E55 PWR's Avatar
e55
any results from dragstrip?
