check engine
Is this common ? I cleared it and it hasn't come back yet.
whats up?
Diy on mercedesshop.com or benzworld.org w210 diy section.
If it fails your engine will crank but it won't run,the cps helps control ignition and fuel injection.
At least you got a code,most fail or start to fail without showing a code at all.
ohlord
http://www.autohausaz.com/search/pro...ition%20Sensor
car has 16k miles on it
At least you know where it is and that it is only 56 bucks to replace if you diy.
ohlord
Do NOT ignore it- it will happen again and every symptom will be worse than previous.
In my case it happened ones almoust a month ago. problem "went" away on its own for a week. Than happened again and again this time with car having troublr starting and finallly stalling while driving.
After getting stranded on ther road for couple of hours, I ordered part from importec, spend couple of ourf tearing a part my baby and finally I'm free to roam around without problems.
It is easy DIY - just requires a lot of patience and right tools to go along.
If you plan replacing part on your own PM me and gladly I will provide some pointers how to do it easy way.
Regards Jack
