MPG for stage I with code3 pulley
Old Jun 25, 2008 | 04:18 AM
gtr886's Avatar
E63 W211 08, C32 W203 02
Question MPG for stage I with code3 pulley
What MPG are your guys getting with the code3 pulley and stage I Let?
Better or Worst compare to the stock?
Old Jun 25, 2008 | 07:33 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Of course it is worse, because you are now playing more with the new found power. I was averaging around 18.5 stock, and with my pulley I now get around 17.6. Its the price you pay for having more fun. My new lifetime with the pulley is still a LOW 14.4, but that is with two track events
See yeah
Old Jun 25, 2008 | 08:02 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
See yeah
+1
It's tricky to say for sure, because once you add Stage I or II power, MRAMG1 is absolutely right - you're dipping into it more, which obviously is going to hurt mpg.
However, I've tried to run nearly identical trips vs. ones I made in the past, and in my estimation I've lost 1-1.5 mpg. This was right in line with my expectation... whenever you increase boost on a F/I engine, you need to increase fuel or you'll run lean. If you have a fuel map that's been adjusted across the rpm range to accommodate the boost for a proper A/F ratio, you're going to be using more fuel pretty much across the board.
Old Jun 25, 2008 | 09:43 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I would agree....definately not going to gain any mpg....
Its definately a combination of the car using more fuel and you pushing her harder now that you can...
I am happy to get 18-19 most times!
Old Jun 25, 2008 | 02:45 PM
TopGun32's Avatar
I don't have a larger crank pulley or ECU flash.. so I can only speak about C3P package
my daily 33mile commute of mix freeway and street driving.. I can manage up to 26mpg at my highest point
Most of the time when I arrive to work my display says 22.5
around town.. its around 17 if feather the pedal and drive in C mode.
if I step on it around town.. it will obviously drop
around the freeway.. on a hot day and really getting on the gas.. usually 20 to 22 mpg.
not bad for a car having over 370+ hp to the crank..
Old Jun 25, 2008 | 03:17 PM
gtr886's Avatar
I’m planning to upgrade my ECU but i don't have a mod pulley. All i have is a code3 intake and Let HE. I read some review says after ECU tune, they see a better MPG.
Old Jun 25, 2008 | 04:40 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
I got about 1-1.5 MPG better consumption on the highway after my LET package...but about 2 MPG worse around town....I can't stay out of the throttle.
Old Jun 25, 2008 | 04:49 PM
gtr886's Avatar
MY MPG is 13 in town and 18 in freeway on the stock ecu.
Old Jun 25, 2008 | 04:59 PM
chuckactor's Avatar
2002 C32 AMG
When I added the bigger pulley my average milage dropped about 2 mpg. I went from about 21 to 19. My commute is 24 miles each way mostly highway. If I baby it, I can get 22mpg average. Broken down I get about 14-15 around town and maybe 24 cruising on the highway.
Chuck
Old Jun 25, 2008 | 05:49 PM
rlee02135's Avatar
2004 C32 ///AMG
I do mostly city driving...average 12.5 mpg with the Evosport ODPS
Old Jun 25, 2008 | 05:55 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
17mpg avg after all the mods. around 22-23mpg on the freeway.
