C32 Dyno 6/28 turbo16lbs & 04blackc32
Old Jun 29, 2008 | 02:56 PM
turbo16lbs's Avatar
1991 Toyota MR2, 2002 C32 AMG
So yesterday me and 04blackc32 saw that there was a dyno day here in South Florida at Lujan Motorsports. We couldn't pass up the opportunity. 50 bucks for 3 runs with a/f ratio is excellent.
We were astonished with the results that we obtained that day in a scorching 96º - 97º temperatures. Our cars have no modifications done to them except for the routine maintenence cycles. So enough with the chatter and off to the results.
These are the first 3 dyno sheets for 04blackC32. The car had the stock 17" AMG wheels with 89k miles on the odometer.
This first pull held a debate as to whether to dyno the car at 3rd gear or 4th. In the end the guy in the car decided to go with 3rd gear for better results.
First pull:
Second pull:
Third pull:
Here are the youtube videos for 04blackc32:
Run #1:
Run #2:
Run #3:
The last 3 dyno sheets were my car which also dynoed in 3rd with 19" HRE 890R rims and 59k on the odometer. The torque reading somehow got screwed up but my HP rating was accurate according to ***** from Lujan.
Torque reading is wrong!
First pull:
Second pull:
Third pull:
Here are my youtube videos for my runs:
Run #1:
Run #2:
Run #3:
Old Jun 29, 2008 | 03:03 PM
kindafast's Avatar
W210 E55 & W204 C63
I think 4th is where you get ther 1:1 ratio for our cars.
Old Jun 29, 2008 | 03:05 PM
c55asleep?'s Avatar
Bicycle
First pull:
Second pull:
Third pull:
Run #1: http://www.youtube.com/watch?v=RwUFdMsNGTo
Run #2: http://www.youtube.com/watch?v=uPlJgDZqF7o
Run #3: http://www.youtube.com/watch?v=aKFDsv4undo
First pull:
Second pull:
Third pull:
Run #1: http://www.youtube.com/watch?v=IN6APy6iSDo
Run #2: http://www.youtube.com/watch?v=Eubmto2e09E
Run #3: http://www.youtube.com/watch?v=FAAeT7ngXyE
Looking good Tony!
Old Jun 29, 2008 | 06:40 PM
Zeppelin's Avatar
C32
You guys should have done 3 more dyno's each, I bet you would have broke the 400hp barrier
Old Jun 29, 2008 | 07:21 PM
moosejaw's Avatar
none
WOW!
Old Jun 29, 2008 | 08:26 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it's the first time i've see back to back dyno number increase every time.
Old Jun 29, 2008 | 08:27 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Yeah especially with the heatsoak our engines suffer. Great numbers though considering the heat! Stock I assume?
Old Jun 29, 2008 | 10:09 PM
turbo16lbs's Avatar
Its the first time I've even seen a dyno.... lol
