Moisture in the headlight
Is it just the seal or do I must replace the entire assembly?
If dealer have to replace the whole thing, i'll be pissssssssssssssssed...
It really suxs that I can't transfer MBUSA Warranty to Korea..
first way: take out your headlight (might have to taken out bumper). remove all bulbs and wiring. Take a heat gun and heat where the housing and lens meet. pry it open CAREFULLY. windex it clean and make sure there are no streaks. might wanna put some anti fog there if you want. and it might be time to black out your headlights too. reseal the housing and lens with some high quality plastic/glass silicone. wrap the headlight over and over again using quick release masking tape. sit overnight and ur done
2) this is the quicker process. if turning on the lights and remove the moisture works, great. Just take the headlight out and put a thin bead of silicone where the lens and hoursinf meets. if not, remove the headlight, bulbs and wiring. take a hair dryer and dry the light and make sure there's no more moisture. reseal with silicone.
hope this helps.
I guess seals are going bad then huh?? I mean, if I can solve this problem by turning on the hid for few hr, that would be great. But, this problem will occur again when it's raining... I've never had this problem before....
Sigh...
Just tell them that the moisture is a lot more in the morning and then as the days goes by it gets less and less. but never goes away.
hope this helps.
Its the same head light sealant nissan, bmw, mercedes, acura and toyota all use.
just click on my tsx diy and it'll give you an idea in how to apply it.
..Korea doesn't have autopart shops like Autozone.. So it's hard to get hold of any tools or parts.. Oh well..Looks like an easy fix.. Thank you all for ur tips / comments! I'll just probably take it to a shop and let them deal with it...
