Sheet metal intake plenums...yes please!
2002 C32 AMG
Alright, I apologize if this is a re-post, but I haven't seen these mentioned yet on this forum. If you don't cruise Crossfireforum.org, you should. There are a lot of SRT-6 guys over there posting up some great 1/4 mile times. If you haven't heard, the Crossfire SRT-6 runs the same engine and trans as the C32/SLK32 AMG. Most of the mods they're doing also fit and work on the C32.
Anyway, here is a new mod that is currently being developed, and looks to be worth some great power gains.
http://www.crossfireforum.org/forum/...ad.php?t=19961
I just don't see where that set-up will give you anything more that what we already have. The curved bend on the closest cylinders to the bump looks promising but the design on the back end by the firewall sucks (and not air). There is room back there so why not a nice square to round transition to the box vs. a round inlet duct into the plenum's?
Doesn't really look like it was designed with the best intentions of moving air in an efficeint manner. Just my 2 cents......
2003 C-Class Sportcoupe
I'd rather have a carbon composite intake manifold. If a similar design were to be made in carbon/kevlar composite, that would be better IMO. My CF guy makes CF intakes for the corvette ZO6, but they are way simpler design than our intakes. The way Needswings made it would make it impossible to use the stock intake. Maybe when I get a chance to install my phenolic spacers, I'll show it to him and ask if he can make a mold of them. Makes me think about a nitrous plate too.
2002 C32 AMG
2002 C32 AMG
You wouldn't pick this up "instead". You would still run your intake of choice, but these open the path AFTER the supercharger. If you ever have your factory plenums off, take a look inside the inlet tubes; they pinch down ridiculously small at the bend.
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
The inlet tubes are indeed a joke, probably why most have gone sl55 splitter etc...
2002 C32 AMG
2005 E55
Why not just make angled plenum spacers to increase the volume?
I used one on my old 350z and gained a nice 11 whp on a N/A engine...
http://www.alteredatmosphere.com/mm5...ry_Code=FX_ENG
2002 C32 AMG
I think the whole purpose of the plenum design that MB incorporated on these engines is to make (low-end) torque. It's actually pretty cool; I've never seen another manufacturer use this design on a supercharged car. However, I believe a better flowing design will let the engine breathe better in the upper RPM.
2005 E55
The volume is a bonus, but I think the real advantage will be larger inlet tubes leading to the back of the plenum. On the factory piece, the inlet tubes pinch down very small right at the bend before entering the "tank" portion.
1 Post
02 c32 99 superduty
Originally Posted by loungn14
bah....i will just pick up the LET intake instead...
I can tell from reading the subpar responses from the majority of members here and I have to say that I'm disappointed. Maybe if it were LET that had designed and manufactured it everyone's responses would be better. Such a shame... end rant...
SPONSOR
If you check closely and knew much about the forum you would notice that the LET boys are friends of mine. The LET intake that "i don't know what i'm talking about" has not been released to the public yet.
If you read prior posts you will notice that I illuded to that.
As most of the tuners that work on these engines noted in prior discussions, the AMG engineers actually did a good job designing the intake on these cars. Just throwing more air at the engine does seem to lower low end torque, something that most of us dont want. We are patiently waiting on the street/dyno results from the needwings.....
Is this the post where you "illude" that you know of a product?
If so why do you refer to the SL55 setup and filter . Dude the intake manifolds come after the air intake system.
Did I read that right? Putting more air into the engine reduces torque Well then you might want to have a chat with any engine builder, they'll gladly tell you that you're full of it. Just have a look at the link below.
http://www.needswings.com/productimages/srt6caidyno.jpg
This is a stock engine with just his CAI installed. Please explain in increase in horsepower and torque...
As a side note: use of the term "intake" has become so generalized that I don't think many people are talking about the same part(s). It's a generation thing. When I was in my teen years when you spoke of an intake, it was in regards to the intake manifold. With the newer generation "intake" has become the term for the air filter system. Since there aren't any (yet released) intake manifolds out in the wild once someone does say "intake..." people assume it is a new air filter system.
I hear ya, but have seen the LET intake, and it is much more than a tube and filter...think along the same lines...
usually, sheet metal intakes gain a lot of power because of the trumpet style runners inside them. The trumpets are hidden inside the ugly intake but increase flow very nicely.
1 Post
not stock.
is there air intake ram-air ? that is the only concern I would have with it... on a dyno it may show more gains but sometimes on a highway / street scenario they are not as efficient... im not trying to bash, just saying it would be all that nicer if it were ram air or at least had air forced / trapped to the filter location..
im holding back on my comments on the intake manifold until i see full dyno results..they look like an interesting piece and im glad they are being built with a "budget" in mind.
