sparkplugs
c32 amg
sparkplugs
still cant wait until i receive the code3 pulley,intake,ph spacers,will i need different spark plugs??or should i stick with the normal ones i got with the car![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
i understand the spark plugs should be gaped??what measurments too??
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I personally went with the NGK plugs from LET. Made a difference. There is a different gap on them, Jerry from LET helped me with mine.
Just remember you need 12 plugs for the C32 (6 per side)
As loungn14 said its 12 plugs total...and it can be a DIY but could be a PITA as for plugs I use the Denso Iridium and I felt it smoother but next time planning on using the kind LET sells.
c32 amg
sparkplugs
so will it be ok if i just re-gap my normal plugs??if no...any seriel no etc etc for the spark plugs you lot mention....want to buy it in the shops over here in the uk instead of mailorder (dont want to wait for it to be delivered)
I haven't done any plug replacements or anything and the car runs like a beast. I wonder if I should start thinking about changing the plugs out or just leave as-is if not having any issues.
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
How many miles are on the plugs you have in now? I bought a pair of long pliers with a loop on the end that helps with the plugs by the firewall. If you are taking the plugs out anyway why not get new?
