How long does the C32 alternator usually last?
2002 C32 Black/Charcoal
Hey!
Was driving on Friday when suddenly a message comes on the C32 multifunction display saying something like "charging system fault." A few minutes later, it says, "Warning, low voltage, consumer fault."
I am thinking that my alternator died. I have 57K miles on the car. Does this sound like the alternator to you? If so, anyone know where to get the best deal on an alternator?
Gracias
Gracias
Hey!
Gracias
Gracias
However, when was the last time you replaced the battery? If it's the original in a 2002 C32, it's probably near the end of it's useful life.
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
I could be the alternator - I had mine replaced at 60K. It was under warranty at the time so I don't have any information for you regarding a good deal on one.
Vomit, that was the exact same malfunction notification I received. The only way to tell for sure was to test for voltage output at the shop.
The dealer wanted about $1600 to replace. I did a little homework and found an independent to do it for about $600. Be warned though, the C32 uses a very specific alternator (with a non-replaceable voltage regulator) made by Valeo. You can't use the cheaper Bosch.
Thanks for the info folks. My battery is a couple of years old (Optima), so I am pretty sure that the battery is not the problem. Sounds like 60K is about when the alternator gives up the ghost.
Anyone know if the C32 alternator replacement is a DIY job (I am not a mechanic, but am capable)?
Anyone have any specifics on where to get the best deal on the alternator (the part itself)? There must be someone online selling them.(?)
Thanks!
Thanks!
Mine went out at 60K also. It was not covered under warranty though.
For the C32, you need part # 112-154-02-02-88. This is the Valeo unit.
FWIW, here's a link where you can supposedly purchase the Valeo unit for $276.89. Personally, I think this is the pricing for the Bosch unit and it could be a mistake on the website - I'd call them and verify. If it is the right part (i.e. it's the Valeo unit), I'd snap it up because that's very cheap for a Valeo unit.
Also, I'm still not convinced that these alternators can't be remanufactured/reconditioned (if it's not a voltage regulator issue). When you remove your old alternator, please save it. If you don't want to check into repairing it, please allow me - I'll pay for shipping. If I can get it fixed, I'll give it back to you.
I had the same problem about a month ago. It is most likely the alternator. I got mine from alleuropeanautoparts.com for $284 shipped, It is the correct Valeo unit and it comes with the poly on itm and it is new one not a rebuild. There is thread out there by FAIRFAXC32 I believe with a DIY. I am going to attempt to install it myself, hopefully today. I'll post my finding on how easy or difficult it is on my original thread. Hope this helps.
ScottW911 is correct. The Bosch unit definitely will not work (at least in the long-term; it doesn't put out enough voltage). Several forum members here have tried the Bosch unit. To my knowledge, it has been a truck-load of fail in each case.
I have the Bosch unit on mine and it's been fine
my original died at about 50k miles with similar symptoms
My technician did the same thing. When he received the new Bosch unit, he found that it would not work and had to re-order the Valeo. I would just play it safe and get the Valeo, even if others feel the Bosch may work.
98 Black C43 , 08' ML320 CDI ,11 E63
I would replace the voltage regulator (usually a $20.00-$30.00 part) before I would do a alternator swap.I find it hard to believe a alternator would go in 5 years.
I found out the expensive way.
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Hey!
Gracias
Gracias
knows what's around the corner.
I ordered the Valeo today from alleuropeanautoparts.com for $284 (free ship). Thanks to all of you who chipped in your .02!!
I will post my comments regarding my experience with the install when done.
Thanks again!
Thanks again!
Alleuropean's unit is the Valeo, but with the wrong pulley. Napa Auto swapped the old pulley on to the new alternator for free.
Also, be advised that you will need a Torx 50 to do this project, in addition to sockets, etc. The removal (both the dismounting and the extraction) of the old alternator is a major PITA. Move hoses/plumbing liberally. I did not find it necessary to jack up the car and did not see the need to access alternator from below.
Main tip: When attempting to loosen the old alternator (after bolt removal), do not try to force it towards the rear of the car. Instead, move it towards the left (passenger side) to slide it out of the brackets. Try a piece of wood and a hammer, and hit it towards the left the best you can.
How long ago did you get this done?
PM me if necessary.
I am in the middle of the same procedure. The Valeo did come with wrong pully as Vomit stated. Vomit, is it working fine with just swapping the pulley?
And I do agree it is a major PITA. I just kept on reminding myself how much I am saving while using very explicit words . My dealer wanted to 2k to do the same thing. They quoted me 1k for the alternator and 1k for the labor .
No kidding, it really is a nasty task the first time. I'm sure that I could do it the second time in a couple of hours, however.
It seems to be working just fine. Today was the first day where I really got on it (0-100, pedal to the metal) and no probs.
Also, FYI, for some reason when I tried installing the top bolt of the alternator first, the bottom bolt then became a beotch and cross-threaded. I then removed both and installed the bottom first (after cleaning the cross thread and applying some WD-40) and it was easy. May have been my screw-up, but I would probably do the bottom bolt first, JIC.
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
mine quit last august mileage 75000 if i remember correctly.
PICKED UP REPLACEMENT AT AUTOZONE FOR $200 MAYE LESS I CANT REMEMBER.
