change pads when lower with just springs?
Old Sep 22, 2008 | 10:17 PM
pointman's Avatar
a car that can't do the throttle reset.
I am reading up on old threads of people who did just springs. I am curious, do I have to change the stock pads to achieve a better look? cause clearly the front end is much higher at this point. I assume the only way to tell whats in there now is when its up in the air with the wheels off right?
Old Sep 22, 2008 | 10:47 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
C32 or C55? When I changed the springs on my C32 to Vogtland springs I never changed out my spring pads/shims. This probably is somewhat dependent on what springs you use though....
Old Sep 22, 2008 | 11:35 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
thats something good to look into, im ready to install RENNtech springs on my c32 and i never thought of that. good point..
Old Sep 23, 2008 | 12:52 AM
pointman's Avatar
C32. Not sure which spring to go with. Any good links on where to buy?
Old Sep 29, 2008 | 10:58 PM
pointman's Avatar
anyone?
Old Sep 30, 2008 | 12:15 AM
SilverBulletAMG's Avatar
C32 AMG
I have H&Rs with a #4 rear pad. Don't have them installed yet though. Was going to replace the rotors at the same time.
Old Sep 30, 2008 | 12:46 AM
pointman's Avatar
How do you know what number you have? And what comes stock?
Old Sep 30, 2008 | 05:00 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
there are DOTS on the pads. only rear has spring pads btw.
Old Sep 30, 2008 | 01:35 PM
pointman's Avatar
Thanks Frank! I knew you'd come thru! So basically I am just gonna get the springs cause I was most worried about getting the front low.. not concerned with the back at all. Thanks again!
Old Sep 30, 2008 | 02:11 PM
C32 AMG
you need the pad to keep the rear from bottoming out and/or rubbing. if you just do springs in the front and leave the rear stock, your handling will be all screwed up. You will want the #4 pad I was talking about earlier....
Old Oct 1, 2008 | 12:34 AM
pointman's Avatar
Hey. So my factory suspension doesn't have the pad? I need to go buy one?
Thanks... I was just about to ask if I could lower just the front. Appreciate the clarification.
Old Oct 1, 2008 | 12:48 AM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
What wheel size do you have? I have 19s with HR springs. I had to replace the rear rubber shim pads to next thicker size to prevent rear tires from rubbing the fenders (which I had already rolled btw) only when you have a full load of adult passengers. By myself, no problem at all.
Old Oct 1, 2008 | 10:25 AM
C32 AMG
Factory suspension does have a pad. I beleive it is a #2, but as mentioned, you can tell by looking at how many bumps it has. #4 is the thickest pad the dealership has. They are cheap also. I bought a pair from the dealership for about $25.
Old Oct 1, 2008 | 02:34 PM
pointman's Avatar
Stock. No plans to go bigger either. I just hate the wheel gap in the front.
Old Oct 1, 2008 | 02:35 PM
pointman's Avatar
Awesome! Thanks again. Really appreciate the info.
Old Oct 1, 2008 | 02:37 PM
pointman's Avatar
H&R Sports from Tirerack a safe bet?
