FAT tires FTW!
put the 235/40/18 PS2 that was sitting in the garage for a month on the car today. match the 265/35/18 PS2 rear.
also few more things to come/fix (ss rear brake lines, euro plate insert for trunk, LED plate light, heat exchanger, and re-tint)
Any issues with rubbing? I've been thinking about the new Kumho Ecsta XS 235/40's and 265/35's for my 18" Monolites when I'm due for new tires (currently, they don't offer it in a 255 rear)... but I'm concerned I might have rubbing issues (lowered on H&R springs w/ #4 pad in rear); IMHO it would really stink after spending close to a grand on tires to only find they didn't fit right...
Car looks very clean
I swear, installing rear lines will make the brakes lose all of that "squishy" pedal feel.
Keep us posted.
I had 19x10 265s 19x9.5 265s with aggressive setup before, so the rear was rolled back then. it's rubbing slightly on the driver side on the trim but that's because I had the trim glued to the bumper and tire's rubbing off the dried up glue/sealant. it only does that when I set the suspension soft. right now i just have it set all the way stiff.
I would suggest to have the fender rolled if you are considering doing the same or go with the brand like Falken or Toyo with less square sidewalls.
Trutaing,
thanks
I just washed it actually before taking that pic. I don't think my brake's mushy at all. the front's are goodridge lines. rear lines are the one came with the 63 rear setup. replacing it with ss line because the passenger line I found it was getting cut by the suspension plastic cover somehow. definitely will have improvement when the rear are also SS lines.
Mike,
...turned out to be the TCU connector pin were crushed by Rusnak tech when they changed the TCU from the last service. Penske also found the TCU wasn't the right one, so the new one was ordered and put in AGAIN. special thanks to my service adviser from Rusnak who went back to work for Penske.
where he goes, I go c32used,
thanks
thanks
wow...that seems like just being careless on the techs part. Another reason why i think no one should touch my c32 except for me.. too bad i'm getting lazy in my older age..lol.
i'm just glad you got it back...
We should do the tech day then the following weekend do another canyon cruise. i know i really want to change out the heat exchanger and radiator.
check out my flickr. http://flickr.com/photos/hippofrank/page5/
car's my childhood friend's, he's more like a little bro.
Looking at those rears makes me want to do mine now. But winter will be here in a month or so
Trutaing,
thanks
Mike,
thanks
