C32 coolant
Old Sep 26, 2008 | 05:17 PM
kindafast's Avatar
W210 E55 & W204 C63
C32 coolant
Hi. I'm going to attempt to replace my coolant and I've been doing some research as well as reading the manual and still have a few questions.
1.) What is the total coolant capacity of m112k? I'm assuming it is around 15 Litres since the manual recommends 7.5-8 Litres of coolant added for optimal performance (50/50 coolant to water ratio). So my question is to go half and half I should put in roughly 7.5L of coolant and 7.5 of water?
2.) Distilled water is best for the water type correct? I read something about adding water wetter but MRAMG said it was useless in daily driven cars, however I push my car a lot what is the optimal ratio of coolant to water for highest reduction of boiling level, and what does this water wetter do exactly?
3.) How do I get rid of the current coolant?
Thanks a lot!
Old Sep 26, 2008 | 05:37 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Thanks a lot!
There's quite a bit of debate on this topic. I'd say stick to the following:
50/50 mix of genuine MB coolant and distilled water You could probably go to 40/60 or 30/70, but the gains really are negligible.
Radiator drain plug is a red knob under the radiator - search for splinter's DIY for changing the heat exchanger, I believe he illustrates it.
Old Sep 26, 2008 | 05:45 PM
kindafast's Avatar
W210 E55 & W204 C63
Great, thank you!
Last question: What is the total coolant capacity of m112k? In gallons or Litres is fine.
That's a very nice 1/4 btw. Did you do it stock?
Old Sep 26, 2008 | 08:01 PM
calimax's Avatar
RENNtech C32 AMG
Great, thank you!
it's about 2 gal once it's gurgled. While I'm filling, I squeeze the top rad hose, put my hand over the reservoir opening and release the hose. You will hear the air moving around and allowing for more coolant. Keep the remaining part of your water with you in the car, the coolant level might drop a little after driving around and trigger the warning light. Do not worry though, it's just gurgling out the rest of the air.
Old Sep 26, 2008 | 08:19 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
sounds like you have done this before
Old Sep 26, 2008 | 08:27 PM
calimax's Avatar
RENNtech C32 AMG
yup yup, and after the 4 hour biting bug infested night of replacing my rad. ugh... I still itch.
Old Sep 26, 2008 | 08:46 PM
kindafast's Avatar
W210 E55 & W204 C63
Thanks Calimax! I've been told the same by my SA and a tech.
But I thought they were wrong and according to "C-Class Operator's Manual" printed in 05/18/2001. I'm looking at page 386 right side. It reads:
"Anticorrosion/ antifreeze quantity
-35 F -49F
C32 AMG only:
7.7 US qt 8.5 US qt
(7.3 l) (8.0 l)"
Judging by "Anticorrosion/ antifreeze quantity" the author is being literal and is refering to ONLY antifreeze, and no water added yet. I was thrown off and thought the guy literally meant antifreeze, but it is the total... meh I bought an extra gallon of this crap.
Old Sep 26, 2008 | 10:28 PM
c32used's Avatar
LET C32 2002
+1
