R1 Concepts Rotors?
C32 AMG
R1 Concepts Rotors?
Has anyone heard of R1 Concepts performance brake rotors? I emailed a rep and below is his reply.
Our Premium Series rotor for the C32 AMG is 300mm in diameter, 22mm thick, 5x112mm bolt pattern and is exactly 16lbs each.
* Exclusive DOUBLE DRILLED “Staggered” design for maximum heat dissipation
* Exclusive DIAMOND SLOTS with R1 Concepts state-of-the-art technology.
* Black Electro-Coat finishes on hubs and vanes to withstand long lasting protection from corrosion, & rust salt water exposure.
* Stronger cast with premium quality iron; longer lasting and stronger rotors.
* Chamfered holes, preventing heat stress, thus, crack issues.
* Reduce warping rotors and brake fading.
* No modification needed; OEM direct fitment.
* Casted to OE specifications
* Double disc grinded:
+ Quicker brake pad bite and break-in;
+ Ensure parallelism & run out.
* Mill balanced; mill-correct to tolerance of less than 2oz. per inch.
o Prevents vibration & warp rotors.
o
Center Split core cast vane structure provides even heat transfer and dissipation.
Braking system is one of the most significant functions of any vehicle. Stopping quicker can prevent life saving, driving accidents. Stopping faster and smoother is for all types of drivers: from daily, to street, track & aggressive. Our Premium-Series brake rotors are truly a premium performance brake product. From how it’s cast from premium quality iron, R1 exclusive double “staggered” drilled & “diamond” slotted design holds up in its ultimate braking performance. Our Premium-Series rotors will last longer and out perform any other rotors out there in the market and works well with any type of brake pads. Our Premium-Series rotors are the best brake rotors we carry!
At R1, we constantly invest in research & design to provide performance drill slot rotors. All of our rotors are drilled and slotted by specifications and tested performance. We do not put holes and slots in a rotor and called it a performance brake rotors. Want more info? -Be sure to click on the auction and read more on why our drilled & slotted rotors are leading in the industry. Our only focus here at R1 Concepts, Inc., is on providing premium high quality brakes at an unbelievable price, backed up with our award winning customer service.
Regards,
D. Long
Sales Representative
Tel: 714-777-2323 ext 7005
Fax: 714-870-6163
For more deals and promotions please visit: www.r1concepts.com
Most performance rotors weigh in around 19lbs and stock is supposed to be about 26lbs. These rotors look and sound great, but almost too good to be true at $250 for a front set.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Thoughts?
o
Regards,
D. Long
Fax: 714-870-6163
Thoughts?
Super Moderator Alumni
As I recall, R1 and L2's are the same product. I have the L2's and thoroughly enjoy them. If the price is right, get them. (I believe the L2's are the E-Line rotors).
I got all 4 corners for $249.
silver, we're on the same boat, as scott stated above about the L2's they were a steal deal !!! I'm trying to call L2 on monday morning to see if they still offer the same deal. Hell, i'll pay 400 for the set shipped if they can do it.
C32 AMG
See if they can do a 2 man "group buy" for us.haha Please let me know what you find out. I have a warped rotor and need to move quickly.
C32 AMG
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
I definitely think we have some bargaining power since we have the different prices C32used and Scott picked them up for vs widely varying advertised prices. Plus they have 2 potential buyers on the table looking for full sets of rotors. At least I am, my as well replace them all at once. Like you said though, I'd be willing to pay $400 for a full set even. We don't need to tell them that though.![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
MBworld Guru
white and whiter
using their product search I didn't see anything came up for C32/55 that's 16lbs each. they listed the weight for two at 53.44 lbs. that's 26.72 lbs per.
the stock C32/55 front rotors are 332mm btw, not 300mm you got in your email reply.
from their email reply they gave you the rear rotor spec and weight.
Inspector frank thanks for the correct info...... i need rotors badly, since i dont drive the 32 too much i been lazy to replace the rotors. Rain season is about to kick in soon in nor cal i have to get these replace asap.
C32 AMG
2008 A8L, 2002 996TT X50, 2009 X5
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
R129, XF Sportbrake, SC400
I have R1 Concept rotors on all fours. I can't say much for their C32 rotors as i don't have one, but i can say that the rotors that i have are great. For some strange reason, my first set of front rotors that i got from them were warped. I called them up and the send me another pair, no questions asked.
Bagged w203 C320/ML430 on 22's
R1's
THEY LOOK GOOD AND ARE ALL RIGHT MINE SEEM TO MAKE A NOISE WHEN I BREAK LIKE AIR PASSING THROUGH THE DRILLED HOLES AND SLOTS OTHER THAN THAT GREAT PRICE AND GOOD LOOKS
C32 AMG
C32 AMG
Either he knew or he didn't; regardless, you need a 345mm x 30mm rotor w/ 5x112 bolt pattern for the fronts - if you tried to use the one mentioned above, it would be too thin, and approx. 1.5" too small in diameter, so your pads wouldn't have enough rotor to grab.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
C32 AMG
You are probably right about the rotors. They may only be offereing rears. I'm about to just say ef it and go OEM. I will wait and see what 1qikctr finds out.
