AMS PULLEY WARNING!!!! video
I have spoken with AMS many times last night and today and they are sending me out a new pulley overnight at no charge just in the small event that the pulley is bad or the pulley went bad. thought that was very cool to do.
I brought the car in the first time thinking that the crank seal was bad and leaking they told me it was inspected and they didnt think it was leaking. 1) how can you inspect a crank seal with the pulley on? 2) If the Crank seal was bad and it was over looked oil leaking out of the crank could loosen the crank bolt right?
Have you ever tried to take one off
I had to use a 4' breaker bar, with a 2' extension. My torque wrench goes to 300 ft/lb, and even at that it didn't even budge.Glad to here AMS sent you another pulley, pretty cool of them
See yeah
PS: From what you explained it appears you found a REALLY good service department
Good luck man, I hope its just loose and NOT malfunctioning or damaging anything else.
btw what are you going to do about your hard earned $600?
And honestly its been wobbling ailttle bit also but not that bad. I had a feeling something was wrong.
I actually feel like now i am losing horsepower escpecially in the high end since my car didnt pully smoothely like it did before i had the AMS garbage in my car.
JUST THINK ABOUT IT, MERCEDES ENGINEERS ARE THE GREATEST MINDS IN THE WORLD, I THINK THEY WOULD OF TAUGHT A LIGHTER CRANK WOULD BE BETTER FOR THE ENGINE, BUT OBV NOT AS THE MOD BUG HIT US AND WE DIDNT DO ENOUGH RESEARCH on the New company AMS, and there ****** bullshat products.
im taking out the AMS pulley and putting back the old one first thing tomm before there any serious damage done to my car.
All of us with the AMS pulleys should take action against This JERRKoff OmeyHomey from benzworld to at least get our money back.
Okay, reality for a moment. First of all pulley instalation is NOT rocket science gentlemen. You simply slide it one, hopefully with the keyway aligned. Now with that being said, even IF it wasn't on the keyway, it should still spin properely with NO wobble. The key ONLY stops it from rotating on the crankshaft, THAT'S IT. So that leaves you with one of two options:
1. Pulley is bent
2. Crankshaft is bent. HIGHLY doubtful as it is forged steel, so rest easy my friend.
Note: This does asume that the pulley is fully seated on the crankshaft and the bolt is tight. Both of witch ANY second grader could do.
So, GET RID OF THAT PULLEY NOW
See yeah
You must hang out with some pretty big second-graders
IMHO, properly torquing the crank bolt takes a lot of effort. 150 ft/lbs, PLUS an extra 90 degrees, is difficult by most anyone's measure... which I think is why some under-torqued pullies have caused issues for m112 and m113 owners (just a theory on my part).hooleyboy,
My guess is that this completely was a service tech error with reinstallation. I mean, if you take it in and it's fine, and get it back and it's like that... what other reasonable conclusion is there? GL with getting it fixed - hopefully no major engine damage to deal with.
Tear the installer a new one for me
I really HATE shops that charge top dollar because its a MB and then have no f____ing clue about what they are doing.GO GET HIM!!!
See yeah
PS: Crank should be okay as I previously stated, its really tuff stuff, Thank God.
IE it's tougher, harder and heavier for a number of reasons.
Question is - when did your pulley start to fail ?
Maybe it had been failing for a while and you just caught it in time ?
Maybe the steel cotter pin began to chip away at the slot leading it to work loose ? (there's been pictures of other steel pulleys suffering damage in that area)
Maybe it wasn't installed correctly or maybe the dealer messed with it ?
Lots of questions and I doubt you'll ever be 100% sure of the sequence of events which lead to the melt down.
Main thing is you caught it in time and it's being taken care of.
sorry to hear the for your inconvenience due to the improper installation, that is absolutely unacceptable.
Even though this was technically not our fault and we were not responsible, we will go ahead and replace your pulley 100% free of charge under our lifetime warranty. We stand by our products and more importantly we stand by our customers. I hope this demonstrates our level of dedication to our customers and shows to what great lengths we will go to in order to make our customers happy.
your new pulley is on the way. Please return the bad pulley so we can properly document it.
Thanks.
Thanks.
Wow, so their blaming Dyno Comp?? Thats a VERY respected tuner that caters to many AMG Mercedes, Porsche, Ferrari, Evo's and STI's. They do that kind of work all day long, unlike some of the freshman techs in the service bay. It's typical fashion for the dealer SA's and Techs to cover their a$$'s when it comes to large problems caused by them selves, I still bet that their lying through their teeth about not touching the pulley. I don't see how you can accurately inspect a crank seal thats behind a large pulley without removing it. And in that case, their probably lying about inspecting the seal.
So they are trying to file down a burr that was created so they can ge the stock pulley on. If they cant do that I'm SOL.
