high Rpm at start up
It should not be a major concern to you.
I let it idle when it started at 2500rpm then it went down to 1500 and stayed there for 30 secs. So i kept shutting it off and restarting and everytime it did something different that wasn't normal. On one restart it kept going to 3200rpm's and then dropping to 2000 and raising again as if it was reving, I checked the gas pedal and it was all the way back, popped the hood, restarted it again and it went back to normal.
Before my first rimary cat went out the car had the same symptoms about a month prior to engine misfiring.
Thanks for the replies though!
up.
I'm thinking about pooring techron in the tank to clean the fuel system up. Could it have any negative effects on the car due to using this after using a fuel booster?
NOS booster is MMT based and wont harm exhaust components unless you use alot of it along with premium. the case may occur where your octane rating is so high that detonation doesnt occur in portions of your mixture, and then the rich fumes are dumped into the exhaust, causing potential harm to cats and o2 sensors.
do your best to eliminate the fuel system from the list of potential culprits. finish your tank off and fill it up with chevron premium. you can even put a bottle of techron in there if you wish.
back when i was 17 my parents gave me a c280 (w202) and whenever anything broke it was my fault. as far as they were concerned cars didnt break unless you abused them... i chuckled when you stated that your dad would take your car away if it broke again lol. you should feel lucky that youre driving a c32 at that age!
You got quite a car there yourself. Anyway thanks for the tips!
