Sound from car?
Old Oct 5, 2008 | 03:42 PM
rploaded's Avatar
C 55
Sound from car?
My car has always made a noise and maybe someone on this board will know what it is or can share if they have it to.
From a stop or even at a roll of 20 mph if you jab the gas for a second or two when you let of do you get a noticeable "tink" sound from under the car?
Sounds like a bushing or something. But its for sure drivetrain related. I am guessing something is flexing I just want to make sure my car is not faulty. I am about 4k from being out of warranty so I want to address all my issues with the dealership.
Old Oct 5, 2008 | 04:26 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
I get a "tink" sound like metal sliding from under the car. I can dupe it by shifting manually and then letting of the gas at low speeds high rpms. kinda sounds like a linkage or something. IF this is what your talking about I have know idea what it is
Old Oct 5, 2008 | 04:34 PM
rploaded's Avatar
C 55
Yep this is it. If the RPM's are over 3500 and you let off the gas quick it goes "TINK" if your on and off the gas you can make it go tink tink tink.
Its very noticeable especially in our parking garage. I hope that is just the linkage shifting its weight around. Just a very odd noise.
The best way to duplicate the sound at home is to smack the back of two spoons together. They will make a pretty good reproduction.
At least I know I am not alone.
Old Oct 5, 2008 | 04:36 PM
viper501's Avatar
06 C55
I'm having a similar issue. Dealer has it right now for analysis on Monday but initial impressions are bushing creak. Sounds reasonable since it started after I compressed and extended the suspension more than usual parking at a park the other day. Started right after I left the spot I was parked in and has gotten less noticeable since then. I can make it do it by putting it in reverse and then backing up a bit. Took it to the dealer in Saturday and put it on the lift. Couldn't see anything hanging down or stuck in anything (was suspicious that I'd put a twig in a drive shaft or axle. I'll report back what they end up doing to fix it.
Old Oct 5, 2008 | 04:40 PM
rploaded's Avatar
C 55
It could also be the suspension loading and unloading.
Try my sound reproduction experiment. If you smack the backside of two spoons together they will make a Tink very close the sound the car makes.
Its just odd and my car has always done it, I just am glad to not be alone in this...
Old Oct 5, 2008 | 04:42 PM
hooleyboy's Avatar
C55,SL55,C63
yep i got the same thing. the two spoon sound is right on the money
Old Oct 8, 2008 | 11:07 PM
viper501's Avatar
06 C55
I got my car back on Monday. Heat shield came loose and was intermittently rattling against the drive shaft. Had me hooked up by lunch along with taking care of a couple other minor issues.
Old Oct 9, 2008 | 01:32 PM
Tump43's Avatar
2014 E350 4Matic
I had that problem myself. Drove over a very steep curb and pushed the driveshaft into the heat shield just where the front of the drive shaft is bolted to the flex disc. This ripped a small hole in the heat shield, the sides of which rubbed against the drive shaft joint and made a terrific noise. I fixed it myself in under 30 min. by getting under the car, removing the offending heat shield, bending it back into shape and reattaching it -- no more noise.
