Misfire issue need help to minimize list of possibilities
Old Oct 21, 2008 | 04:34 PM
Newzchspy's Avatar
PLAID
Originally Posted by loungn14
Vic,
Bring it over to Fluid Motor Union by us. They are really good guys and are the ones that found jerry's misfire (bad cats) Me and andy will have our cars there this or next week for some additional work as well.
If its a coil pack, swap the pack with another one and see if the error follows the pack.
I have a good feeling though, that it is the cats...
As well as me in the next few weeks too Jerry talked me into it!!
Old Oct 21, 2008 | 04:51 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Originally Posted by Guran
Remove the plenum and check for Intercooler leak.
I have the same problem. Random misfire
/Göran
Good advice.
Old Oct 21, 2008 | 06:14 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Originally Posted by Newzchspy
[/B]
And Code III just introduced the Spearco solution for about $1000 K
For that much, why not just buy a Veyron...
Old Oct 21, 2008 | 08:30 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
Originally Posted by c32used
How is that test perform?
compression/leak down?
he's talking about something like this.
http://www.youtube.com/watch?v=9U8iNb21arw
basically if your engines tests even across all cyclinders you have a pretty healthy engine. If the difference is more then 10% then there might be some issues with your engine.
Old Oct 22, 2008 | 12:15 AM
c32used's Avatar
LET C32 2002
lets hope it ain't no where near that
c32used's Avatar
LET C32 2002
Old Oct 22, 2008 | 12:18 AM
  #32
c32used's Avatar
LET C32 2002
Vic,
If nothing by the Friday then I will make an appointment
Old Oct 22, 2008 | 12:24 AM
  #33
c32used's Avatar
LET C32 2002
Question
Originally Posted by LETMotorsports
Vic - We will figure it out. Drive over to Fluid and have them take a peek at the cats for you.
Lets see...I am checking with Sam in the AM on Wednesday...loosening the cats and driving it hard to see if misfire continues...if misfire stop how can I tell if its the Secondaries or Primaries? I take it I should do one side at a time to see which set of cats may be the culprit? Also Reaer SAM does anyone have a used one for sale? Anyone have Schematics for the rear SAM?**cough** Splinter
Old Oct 23, 2008 | 03:13 PM
  #34
c32used's Avatar
LET C32 2002
Ok bought a bottle of Octane booster and Cheveron Techeron and refilled with 93 octane for the 4/5th time in a row...well I took a 9 mile ride both ways with my friend and he was able to create the misfire again...pulling current codes it showed P0300,P0301,P0304 AND P0108....which P0108 is new showing map sensor stuff. Anyway took 1st plug off each side and they look alike but front left (1st cylinder) spark plug one it showed .45 gap while front right(4th cylinder) at .41 gap. I am planning on buying all new plugs and replacing them as well as the map sensor.
Old Oct 23, 2008 | 04:28 PM
  #35
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
ah..well that doesnt help either.....if your running over to fluid on st let me know. I got hawks tickets bout could meet you over there around 3
have you pulled the ecu lately?
Old Oct 23, 2008 | 04:42 PM
  #36
c32used's Avatar
LET C32 2002
Spoke with Jerry and he feels the culprit is the plugs so buying a new set(even though told no need to just to regap to .33) and going to change them. He really feels that the different gaps are causing this issue especially with me running this much boost. He even offered to take a day off work to help me out...what a classy guy
Old Oct 23, 2008 | 04:59 PM
  #37
loungn14's Avatar
SPONSOR
that's Jerry for you.....you doing the plugs yourself or having fluid do it for you? That drivers side rear is a PAIN!
Old Oct 23, 2008 | 05:17 PM
  #38
c32used's Avatar
LET C32 2002
Talking
Well its cheaper to do it myself and I know the firewall plugs are a PITA!!!
I may drive by Jerrys' the next weekend and have him help me if he could
Old Oct 24, 2008 | 10:37 PM
  #39
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Well its cheaper to do it myself and I know the firewall plugs are a PITA!!!...
Any luck with the misfire yet, Victor?
Old Oct 24, 2008 | 11:17 PM
  #40
c32used's Avatar
LET C32 2002
Talking
Well based off stuff I tried it looks like the Spark plugs are the culprit they are on there way bought a new set of Denso IK20s from Ebay and are in transit..............hopefully it can be installed before dragway season is over...I need to have Glenn see taillights ....to make sure my old 89 octane is fully out of system
Thanks for asking
Old Oct 25, 2008 | 07:58 AM
  #41
e240TT's Avatar
E 240
normally the misfires are ..
coils/supressors/plugs..
and a blocked/damaged cat would case it too, it happened to me b4.
Old Oct 25, 2008 | 04:34 PM
  #42
c32used's Avatar
LET C32 2002
Well after checking two spark plugs from each side of engine and one gapped at .41 while the other is at .45 well my extra boost seems to trigger the misfire when pushing the throttle hard. So hopefully after changing to new ones the misfire is gone. I also have the factory wires and will replace the if necessary to weed out the wires and plugs
Old Oct 25, 2008 | 06:31 PM
  #43
Newzchspy's Avatar
PLAID
Its a boost problem, I doubt the plugs are doing it. Seriously, this all started after you took off the ASP and put the 185 on. Betcha that if you remove the 185, problem will go away!! Engine can't take the boost, the heat (or the driver). Now, who is showing whom taillights? Only one's I have seen are Jake's?? Wanna try my Code III
Old Oct 25, 2008 | 06:47 PM
  #44
c32used's Avatar
LET C32 2002
Talking
Well we'll see if the plugs are the issue and its on hopefully the belt wrap will help you but I had no worries trying you with the 178 what makes you think I will worry with the 185? Remember I and Jake are the same when he did the 12.4 now only difference is a 50 shot, LET intake, cyro to 12.33 but I think with good DRs that 12.3 is attainable. I have the best C32 guy helping me with the misfire its will be solved.
Old Oct 26, 2008 | 01:00 PM
  #45
loungn14's Avatar
SPONSOR
we will figure it out....We also just need to see if the belt wrap kit fits the 185....hint hint brandon...
Old Oct 27, 2008 | 09:56 AM
  #46
Eurocharged Canada's Avatar
SPONSOR
Mercedes/ BMW/ Audi
Glenn - With his plugs gapped at .41 and .45, 22 PSI is blowing out his spark causing the misfire.
They should be gapped at .34 - .38 max.
Why wouldn't his car be able to take the boost when others can?
This quote is right out of a repair handbook in my garage.
"Random misfires may be due to fouled spark plugs, plug gap too wide, bad plug wire, weak ignition coil, cracks or carbon tracks in an ignition coil."
This is a common problem on high boost cars.
http://www.google.com/search?hl=en&r...lows+out+spark
You are right, changing his pulley back to ASP would fix the problem....because it would remove 5 lbs of boost.
Old Oct 27, 2008 | 10:50 AM
  #47
c32used's Avatar
LET C32 2002
Thumbs up
Guys this forum is for the educated minds/Gearheads..everyone has their personal opinions on how things happen or work...I feel even by going back to an ASP that the problem is only being masked....I trust the 185 pulley and know our cars can handle it rather its close or not(Jake among others is doing quite well).....I know improper gapping can cause an issue and the fact I have stressed the spark plugs by drag racing the car some I can see how plugs, wires, or other things can start to fail sooner then later...........because its a high load misfire I can see how the improper gapping is causing misfires and the codes always show P0301 and P0304 which to me means cylinder 1 and 4 the ones with the gapping issue as well as P0300...so lets try it first....if for some reason its not I am confident Jerry will help me find the cause...right now new replacement plugs is all I bought but I still have the OEM wires if we need to replace the wires. If I drive normal and even step on it I usually can't get the misfire to happen again. Honestly I don't think anymore this is anywhere a complicated issue as I originally made it sound.....but honestly guys your possible solutions are very welcomed and will be tried if all others fail
Old Oct 27, 2008 | 10:56 AM
  #48
c32used's Avatar
LET C32 2002
Talking
You mean mask the existing problem
Once I get the plugs I will visit you or vice versa which ever works best....that way I can give you that thing I have for you
Old Oct 27, 2008 | 11:03 AM
  #49
loungn14's Avatar
SPONSOR
good post jerry.....hence the exact reason I got new plugs and wires when I got the 185, and made sure they were gapped correctly...
insert joke here glenn......
Old Oct 27, 2008 | 03:00 PM
  #50
jgsx's Avatar
04 C32
I had this identical problem ~6 weeks ago (misfires only under high load/high RPM shortly after installing a larger pulley). First thing that popped into my head was plugs, but after reading the plugged cat threads on here, I figured that was it. Checked the cats and they were fine. Checked the plugs and they gaps were off. Put in a fresh set of properly gapped plugs, and the problem went away.
