Misfire issue need help to minimize list of possibilities
They should be gapped at .34 - .38 max.
Why wouldn't his car be able to take the boost when others can?
This quote is right out of a repair handbook in my garage.
"Random misfires may be due to fouled spark plugs, plug gap too wide, bad plug wire, weak ignition coil, cracks or carbon tracks in an ignition coil."
This is a common problem on high boost cars.
http://www.google.com/search?hl=en&r...lows+out+spark
You are right, changing his pulley back to ASP would fix the problem....because it would remove 5 lbs of boost.
Just razzing him JERRY!!!! He loves the attention. I lay off him when he breaks into the 12s.
Speaking of which, what is the recommendation for 1. Plugs and 2. Gap for those plugs?
Glenn
BTW: anything less than 93 in the C32, and it doesn't like it; just not the same car. (Not brand specific)
Just my .02:
Just my .02:
: Or you could run 89 Octane from this station and run a 13.2
Since plug replacement car runs fabulous with no misfires and the old way of thinking of running 89 octane fuel is out the window...thank God the fuel prices are quite a bit down
I can save money now while before I had to visit the bank frequently.
It was as AMG-Jerry stated the plugs
maybe between .33-.37
