Misfire issue need help to minimize list of possibilities
Old Oct 20, 2008 | 04:36 PM
c32used's Avatar
LET C32 2002
Question Misfire issue need help to minimize list of possibilities
Guys I have a heavy load misfire. While driving car normal its non existant but when romping on it I have gotten check engine light flash and checking error codes it shows multiple engine cylinder misfire. These are the two probable causes told for me to check
1. loosen bolts to pipe that ties cats to system to see if misfire goes away
2. my rear SAM controls my feul pump and seems to not be cummunicating or working right
any ideas or suggestions?
While at the track Saturday adaptations were cleared and on run it happened and even Jerry installed another Tune and it almost made it til the end then misfire happened.
Old Oct 20, 2008 | 05:20 PM
Zeppelin's Avatar
C32
What code are you getting?
If a P0300 then that will be hard to find.
I would check to make sure all you ignition wire and coil pack wiring is tight. Might even be time to replace the ignition wires if they have a lot of miles.
Old Oct 20, 2008 | 05:27 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
need the codes vic...
Old Oct 20, 2008 | 05:31 PM
Newzchspy's Avatar
PLAID
Question: What octane are you running Vic?? 87, 89 or 93??? That could cause a CEL code too with your mods. I haven't heard of many problems with the LET Crank pulley causing misfires or CELs so lets look elsewhere?? Plugs??
Fuel issues??? Do you consistently run the 93, if not you should??
Old Oct 20, 2008 | 05:53 PM
c32used's Avatar
LET C32 2002
I would use in the past back maybe 3 weeks ago 89 Octane but 93 since...battery died on Code reader so will buy new Battery in a bit and see if it stored the error codes the adaptations were cleared and another Tune installed and it almost made it down the track and then misfire.
Anyone who don't know in Chicagoland area our Octane grades are 87/89/93.
Also no one is blaming the pullies or Tune.
Old Oct 20, 2008 | 06:37 PM
Newzchspy's Avatar
PLAID
Why would you ever run 89??? That's just above regular here?? Big diff between 89 and 93 as well?
Let me ask you this?? Did you have the problem BEFORE the change from the ASP to the new pulley?? Sounds like a fuel issue to me. Either wrong grade or delivery issues. If it only happens on the top end, then you're not getting enough gas?? 89 can do that too if you're still running through a tank of that?? Come on Vic, 89 is like doing this to your engine and 93 is like this 100 is like this
Old Oct 20, 2008 | 06:57 PM
5.0seven's Avatar
1980 rx-7 with a 302
i by no means have any insite on Mercedes issues. however it sounds like either a M.A.P sensor or M.A.F sensor to me. its a cheep test.... just spray some mass air flow cleaner on either sensor.....
or dont lol.... just throwing my 2cents out there
Old Oct 20, 2008 | 07:11 PM
Newzchspy's Avatar
PLAID
Good point!!! Or some 89 Octane gas? That'll do the trick. Victor, I am so very disappointed in you!!!
Old Oct 20, 2008 | 11:25 PM
el_ke_veinte's Avatar
C32 AMG
get a compression test or a leak down test to be sure there's nothing mechanically wrong inside your engine.
Old Oct 21, 2008 | 12:12 AM
c32used's Avatar
LET C32 2002
As I recall the C32 has neither a map/maf sensor to worry about
Old Oct 21, 2008 | 12:13 AM
c32used's Avatar
LET C32 2002
Nothing less then 93 Octane from here on...even if its not the cause.
Old Oct 21, 2008 | 12:14 AM
c32used's Avatar
LET C32 2002
Question
How is that test perform?
compression/leak down?
Old Oct 21, 2008 | 12:17 AM
c32used's Avatar
LET C32 2002
I will have to write down code next time it happens...my code reader was completely dead thus no codes saved.
Old Oct 21, 2008 | 12:21 AM
c32used's Avatar
LET C32 2002
Question: so lets look elsewhere?? Plugs??
I have Magnecor wires and Denso Iridium IK20 plugs just over a year and 4 months used. Jerry on Saturday checked to see that coil pack and wires were snug.
Old Oct 21, 2008 | 12:30 AM
5.0seven's Avatar
hmmmm. is the car speed density? basically im wondering what type of sensor on your car determines how much fuel is delivered. normally cars have a throttle position sensor in adition to another sensor. im not too familiar with Mercedes products... sorry = (
as for peforming a compression test it involves renting a compression tester (basically a psi guage) from autozone or wherever. you take a spark plug out and put the pressure gauge adapter in the hole. unhook your distributer and or efi relay (or fuse depending on the application). crank your motor over for approx 15 seconds and read the gauge it will give you a compression number to check against factory specs. repeat this for every cylander. This test allows you to see weither or not there is low compression with in the cylander wich might indicate a blown head gasket/ broken/ dammage piston rings/ dammaged pistions or dammaged cylander walls.
a leak down test is basically the same thing however it is slightly more complex and should usually only be dont if there seems to be an issure with the compression numbers.
Old Oct 21, 2008 | 12:40 AM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Victor,
I would check the following:
MAP sensor
Fuel Filter
Cats
If you were running 89 on a "hot" tune, your car could very well have been dumping fuel and has killed the Cat in the process.
A plugged Fuel Filter can cause similar issues, and a lazy MAP can give incorrect boost readings and consequently the incorrect fueling maps for the actual boost.
Please keep us informed.
Old Oct 21, 2008 | 12:42 AM
jturkel's Avatar
02 C32 AMG
C32s have MAP sensors
Old Oct 21, 2008 | 01:08 AM
c32used's Avatar
LET C32 2002
Thumbs up
Originally Posted by ChicagoX
Victor,
MAP sensor
Fuel Filter
Cats
I didn't know the C32 has a map sensor...thanks!
Where is the map sensor located? Also how do you check it?
I am checking cats tomorrow by loosening and running car to see if misfire occurs
how can one check a possible clogged feul pump?
Old Oct 21, 2008 | 01:09 AM
c32used's Avatar
LET C32 2002
Old Oct 21, 2008 | 01:10 AM
c32used's Avatar
LET C32 2002
Just found out there is a MAP sensor...sorry.
Old Oct 21, 2008 | 03:54 AM
Guran's Avatar
SLK32 AMG
Intercooler leak ?
Remove the plenum and check for Intercooler leak.
I have the same problem. Random misfire
/Göran
Old Oct 21, 2008 | 08:30 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
c32used,
To add to your list... you might have a bad ignition coil pack. If the code is "random cyl misfire" and not an identified cyl. misfire, this is less likely... however, I had this problem on my M111K coupe - would be fine driving, but under heavy load would pop a CEL and run very rough - changed the coil packs and it was good as new
GL diagnosing your problem... hope you get it running right soon, I'm sure it's a beast with the new mods
Old Oct 21, 2008 | 08:55 AM
loungn14's Avatar
SPONSOR
Vic,
Bring it over to Fluid Motor Union by us. They are really good guys and are the ones that found jerry's misfire (bad cats) Me and andy will have our cars there this or next week for some additional work as well.
If its a coil pack, swap the pack with another one and see if the error follows the pack.
I have a good feeling though, that it is the cats...
Old Oct 21, 2008 | 09:07 AM
Eurocharged Canada's Avatar
SPONSOR
Mercedes/ BMW/ Audi
Vic - We will figure it out. Drive over to Fluid and have them take a peek at the cats for you.
Old Oct 21, 2008 | 04:33 PM
Newzchspy's Avatar
PLAID
/Göran
And Code III just introduced the Spearco solution for about $1 K
