Tein SS Coilovers on C32
My current setup:
Front: Wheels:19X8.5 with 35mm offset, Tires: 235/35/19
Rear: Wheels:19X9.5 with 30mm offset, Tires: 265/30/19
Let me know
Your rear offset is pretty aggressive also. If you go lower you may rub the fender lip. Most folks run ET 35 in the rear with coilovers.
Tires make a big difference with coilovers also. Fat/non rounded tire walls make it harder to clear the front coilovers, while it increases the chances you rub against the fender/inner wheel well on the rear.
If you just want a mild drop without buying new wheels, I would suggest that you just get H&R springs + Koni yellows.
I have the TEIN SS and loves it. I adjust my dampen setting depending on my mood quite often. no other adjustable coilover is as easy to adjust as the TEIN SS.
the rest just follow trutaing's guideline.
well said, I'm having a hard time adjust my pss9's Retarded Design.
Also, without dropping the car, will I get rubbing?
I think your SS is the same if not better on the streets &TRACK
