What wiper replacements you all using?
Old Nov 13, 2008 | 03:20 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
I did a search on wiper blade replacement c32 and came up with zippy. Is it better to replace the entire wiper blade arm or just the rubber part? Mine are showing age and need to replace. Thanks all.
Old Nov 13, 2008 | 03:42 PM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
I just replaced mine with a complete Bosch unit. You cant find just the rubber I dont think.
Old Nov 13, 2008 | 03:48 PM
trbo2nr's Avatar
You have a part number? I imagine it should be the same for an 04. Thanks.
Old Nov 13, 2008 | 03:53 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
I just went to the local Pep Boys and bought the generic 22" and 24" rubber blades. I wanted to keep my original aero-wing on the driver's side arm.
They work just fine.
Old Nov 13, 2008 | 04:24 PM
trbo2nr's Avatar
Good to know. I think there's one close to me. I'll check out this weekend.
Old Nov 13, 2008 | 05:16 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
Just curious, what particular brand blades you got for the driver side. I picked up a bosch at Kragen's but could not install the driver side blade because it did not have the right threaded tabs to mount the wiper spoiler. I'ts $28.00 at the stealership and they say you can only get the C32 OEM replacement driver side wiper (which includes the spoiler) from MB and there are no after market blades available specifically for the C32s.
Old Nov 13, 2008 | 05:20 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
2002 wiper blades are the old-school design, 2004's are definitely the newer design (similar to Bosch Icon blades).
www.autohausaz.com has OEM blades for very reasonable prices. If you can wait, I'd just mail order 'em if I were you.
Old Nov 13, 2008 | 06:10 PM
trbo2nr's Avatar
Yeah, just need to get through tomorrow and chances are I can wait. Thanks for the link,
Bob
Old Nov 13, 2008 | 07:28 PM
60n5pt1's Avatar
When you say 'old school design', are you pertaining to the wiper blades or the actual driver side arm assembly that the wiper spolier mounts to.
Of course, if one can purchase new blade technology, one will not hesitate to avail of it. BUT, will it fit the OEM arm assembly. To change the blade on the driver side, you need to remove the spoiler. If the replacement blade does not have these threaded tabs, you have nothing to mount the spoiler back onto. And yes, I was able to install the blades, but, could not mount the spoiler back on without those threaded tabs.
I think only the C32s in the W203s have a driver side wiper spoiler.
Old Nov 13, 2008 | 07:43 PM
c32AMG-DTM's Avatar
Sorry if I was unclear. When I said "old school design" I simply meant the wiper blade variety that has a blade insert, and several hinged points of contact on the arm. Yes, these also have a spoiler on the driver's side - my understanding is this is primarily to improve function at autobahn speeds. My 2002 MY C230 Coupe had these wiper blades as the OEM parts (with a Dr. Side spoiler).
In 2004 (perhaps 2003) MB switched to the newer wiper blade design that has a blade insert in a flexible, continuous radius blade arm. It looks very similar to the blade in this picture:
http://www.boschautoparts.com/Products/WiperBlades/Icon
Old Nov 14, 2008 | 03:39 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
BOSCH ICON blade. adjust the passenger side default position. done. 22" and 24" or 22" on both side. either way.
Old Nov 14, 2008 | 07:52 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
shoot, i have the RENNtech carbon fiber aero dynamic crock skin mixed with snake skin, to wipe out all the water smoothly while adding 15 ponnies to the crank.. you should try it, its gotten me more ladies than fifty got mercedes..!!
Old Nov 18, 2008 | 03:59 PM
trbo2nr's Avatar
I ended up with these. Perfect fit.
Bosch 3397118933 Aerotwin Original Equipment Replacement Wiper Blades - Set 22"/22"
Old Nov 19, 2008 | 12:09 AM
dac086's Avatar
2003 c320
where did you guys get these blades from? amazon?
Old Nov 19, 2008 | 06:34 PM
trbo2nr's Avatar
Plug that part number into ebay and buy it. Most places were $$ and ebay was $33 or so.
Old Mar 11, 2009 | 09:17 PM
dac086's Avatar
2003 c320
i got the bosch blades but dont work. my original blades have the clip that slip on them but the new ones cant fit the clip, any ideas? do all of your wipers have the same clip that i have?
Attached Thumbnails What wiper replacements you all using?-img00008-20090311-1805.jpg   What wiper replacements you all using?-img00011-20090311-1806.jpg
Old Mar 11, 2009 | 09:23 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Weird, mine are Valeo's.
Old Mar 12, 2009 | 10:04 AM
kevkranker's Avatar
C32
I got the Bosch but the passenger side was rubbing the window trim on the side so I replaced the 22" with a 21" Bosch and now no rubbing.
Old Apr 7, 2009 | 05:43 PM
///AMG4EVER's Avatar
CLS55 Designo 030
Have someone installed these Bosch 3397118933 blades on a 2002 model?
I'm having a hard time figuring this out, maybe the arms are different.
Old Apr 7, 2009 | 05:50 PM
trbo2nr's Avatar
No, I installed the following on a 2004 and works great.
I think I paid $32.
Old Apr 7, 2009 | 05:53 PM
CLS55 Designo 030
Thank you.
If I remember correctly, the 2004 models came with the updated wiper design. I noticed Frank did his and he has a 2002 so I wanted to double check if I need additional parts to make the conversion.
Thanks again - Carlos
Old Apr 7, 2009 | 05:54 PM
trbo2nr's Avatar
Thank you.
oh- ok. I didn't know that. I learned something new.
Old Apr 7, 2009 | 06:38 PM
Tump43's Avatar
2014 E350 4Matic
I got replacement Valeo wiper blades for my C55 from Autoparts Wharehouse. Same as OE work just fine (pt. no.203 820 1545). Something like $15 each. Yes, these are the ones with clips shown in your left picture.
Old Apr 8, 2009 | 11:07 PM
c32used's Avatar
LET C32 2002
Can you post generic brand name.. gonna see if local autozone,advance auto or walmart has them...I want to replace mine...also it looks like EBC will be my next rotors they are made in the UK...thanks for the link
