*STOCK C32 / M112K owners: Check your OE Idler pulley!!!*
Rating: Thread Rating: 2 votes, 5.00 average.
Old Sep 10, 2009 | 12:04 PM
  #51
Newzchspy's Avatar
PLAID
Originally Posted by Rudamentz
Just wondering, Mine blew up so if its a recall that would be great!
In the alternative, Needswings has a new pulley replacement kit for this very issue for SLK/C32/SRT-6 cars.
Old Sep 10, 2009 | 01:07 PM
  #52
320 dreamer's Avatar
2003 porsche 996 turbo
Originally Posted by Newzchspy
[/U][/I][/B]
its a great setup but it only works if you are running a larger crank pulley. after many emails with rob the conclusion was that with a c3 and oem pulley setup his wont apply.
i had 3 pulleys with imminent bearing failure so for the cost of 100$ or so replaced the pulleys now have the peace of mind that my system is good for a few yrs!
anyone who tinkers with their car should drop the belt and inspect all the pulleys. its easy and can save you thousands of dollars down the road
Old Sep 10, 2009 | 01:34 PM
  #53
jimmyp's Avatar
Are the to pulleys the same????The ones with the bearings in them.I think the others have no bearings.
Old Sep 11, 2009 | 05:06 PM
  #54
not sure which ones you mean. i replaced the grooved pulley next to the s/c pulley, the s/c pulley with a c3 pulley and the idler pulley under the s/c pulley.
the first was 10$ the c3 450$ and (also new bearing for the oem s/c pulley just to have a spare 56$) and the idler pulley 56$. only the s/c has just a bearing replacement. the others just replace the pulleys with new ones
Old Sep 11, 2009 | 06:20 PM
  #55
pointman's Avatar
a car that can't do the throttle reset.
Have many people run into the pulley quitting on them?
Old Sep 11, 2009 | 06:25 PM
  #56
not sure of the answer but i reply with this. i spent less than 200$ on bearings and if it saves me from lunching my 7000$ s/c or 350$ water pump or keeps a pulley from ping ponging around my engine compartment crashing thru my hood ill say it was good insurance
Old Oct 9, 2009 | 01:11 PM
  #57
Charmer's Avatar
C32 AMG
This really is a great thread.
How noisy should the supercharger be at idle?
I have replaced the s/c pulley bearing and the old bearing was definitely well worn. No problem with the idler pulley.
When I was using the stethoscope I noticed quite a racket coming from the front of the supercharger unit, it is also audible to the naked ear. However I can hear the same noise on the video clip in the original post.
How noisy are your superchargers at idle???
Old Oct 10, 2009 | 09:01 PM
  #58
ML500K's Avatar
C32 '02
mine is relatively quite for now. will post a before and after code3 pulley clip when i receive it..
I did have my sc bearing changed 5000mi back. i also changed all three pulleys #6,#4,#9. ( #4 & #9 use both the same new part as detailed by the OP )
Old Oct 10, 2009 | 09:02 PM
  #59
jturkel's Avatar
02 C32 AMG
not sure if this has been covered in this thread, BUT
my LET middler idler with the upgraded bearing failed after 6 months. just be weary for excessive and unusual noises emanating from the engine bay.
Old Oct 20, 2009 | 12:23 PM
  #60
uweb's Avatar
C32 '02 silver 70K
Originally Posted by boohooramblers
In light of recent thread activity on the forum, here is a rather lengthy write-up of a recent experience with my OE idler pulley. Also included is a write-up of the installation for a new idler pulley.
For those who don’t want to read the whole thing, scroll to the conclusions section.
Background:
Case: I have a 2002 C32 AMG with 76K miles. No over- / under-driven pulleys. The poly V belt and all pulleys are in good shape esthetically, and there is minimal rotational wobble in any of the pulleys at idle. I have never removed any of the pulleys and the vehicle’s records (VMI) are also clear of any pulley work.
Introduction: I noticed a ‘louder’ sound coming from the engine bay at start-up one recent morning. Like many of my dealership experiences, I could never reproduce it to grab some video! Aside from the 5 minutes of weird whine, I never heard it again. I initially dismissed the sound as ‘normal’ due to the passage of cooler and better air through the intakes and supercharger. The evidence that partially led to its identification was the fact that it got louder with increasing engine revs.
Hypothesis:
My POS idler pulley is transmuting into a potentially catastrophic projectile.
Materials and Methods:
Stethoscope / tubing, mechanic’s gloves, Torx sockets sized E10 and E12, 15mm socket and wrench, torque wrench (15 ft.lb / 180 in.lb), credit card, and ½ beer (job didn’t take long enough for a full one!).
First, let’s alleviate any confusion by first identifying the pulley in question:
It is pulley #4 in the diagram below. This pulley is also known to MB aficionados/techs as a ‘Tightening’ pulley. It’s the same thing.
Checking for abnormal pulley sounds: Obviously I visually checked and put my ear up against all the pulleys; however, I wasn’t able to hear anything of note. That’s where the stethoscope / piece of rubber tubing is of use. With the engine running, place the piece of tubing very close to the pulley and you will be able to hear any abnormal sounds (please be careful doing this!). For my idler pulley, there was a nasty raspy sound coming from the pulley – most likely an early bearing problem.
Removing the idler pulley: This takes less than 5 minutes (seriously). For those of you not familiar with the procedure, check out the lame video I made of the various steps. Note that you don’t have to remove the upper SC guide pulley, but I wanted to remove it so I could check its integrity and it helps to have it out of the way.
1. Make sure the engine is OFF and preferably not hot! Some people may find it prudent to disconnect the ground on their battery and / or unplug your radiator fan.
2. Remove engine cover.
3. Get the air lines/tubes out of your way by pulley away from the engine (firm but gentle) and remove the torx-head fasteners (2 x E10 torx). Push the air lines away to the left of the engine. If you think the procedure will take some time, you may want to cover the open ends of the tubes and inlets.
4. Slip the belt off the idler pulley by turning the belt tensioner counter-clockwise (E10 torx). After slipping the belt off, slowly allow the tensioner to spring fully back clockwise.
5. If you are checking the SC guide pulley, remove the black bracket that fastens the pulley and holds the belt in place. Superior (top) fastener is an E10 torx and anterior (facing the engine) is E12 torx. The SC guide pulley comes off with the assembly.
6. Remove the idler pulley using a 15mm socket wrench.
7. Reinstall in the reverse order starting with the idler pulley. Use a new bolt and tighten this bolt to a maximum of 15 ft.lb (180 in.lb). Use Locktite if you feel it needs a little more holding power!
8. Obviously an extremely important step when reinstalling the belt is to make sure it is in the correct orientation and that it is aligned exactly with the grooves on the pulleys. You will experience a big truck-load of FAIL if you do not do this.
Here’s a low-quality video showing the various steps.
Results:
Importantly, there was no tell-tale screeching of the pulley. It was just a slightly higher pitch whine/drone than the motor sounds and it lasted for 5 minutes. I eventually identified the source using my stethoscope. There was a nice normal whine coming from all pulleys except one. A nasty raspy whine coming from the idler pulley (#4) – again, through the stethoscope (it wasn’t otherwise audible).
On my car, the OE part number is 112 202 00 19. This part has been replaced by part number 112 202 01 19. The pulley was $72 and included a new bolt and cap.
My old idler pulley (112 202 00 19) has a bearing from NTN. The bearing type is 6303 LHA (and the color is yellow). The bearing in the new idler pulley is 6303 RDD (C3 5C OR5) (color is green).
Here’s a composite of the new and old idler pulleys:
Visual test: no abnormalities could be seen superficially. The bearing seal was intact and I couldn’t see any bulging / deformities or grease.
Spin test: deplorable! As you can see from the video, this pulley is not a happy camper and is not spinning freely. Clearly the bearings are failing (for comparison, compare the video of the new idler pulley rotating). That finding was definitely sufficient for me to get a new pulley.
Here is a video showing the old and new idler pulleys spinning:
Torque value for tightening the idler pulley bolt: 14-15 ft.lb. I got this value straight from the techs at my MBZ dealership.
This torque value is extremely important because stress is placed on the bearing if you over torque this bolt. Increased stress ultimately means decreased life of the bearing. Since this torque value is relatively low, I used Locktite on the bolts for extra peace of mind.
Conclusions:
Your STOCK idler pulley bearings may be failing – even if you don’t hear or see any problems right now! Note that you don’t need any power-adding modifications for your stock idler pulley to fail!
For the sake of 15 minutes, if you have a higher mileage M112K, I think it is worth it to check your idler pulley (and others) to make sure they are structurally and functionally sound. To do this, you need to have a stethoscope (or length of hosing) to amplify the sound coming from the pulley.
While you’re at it (especially you guys who have changed your pulleys in order to accommodate a larger crank pulley), check for play in the belt. If the belt is off, lateral forces can definitely contribute to the failure of the bearing. It’s simple physics.
Even though I heard an abnormal pulley bearing sound for about 5 minutes, I’m sure the bearings on the pulley would start to make much more noise when it is getting closer to complete failure. We may be playing with fire if we want to wait for audible confirmation that our idler bearings have failed.
If I have omitted any important details, let me know so that noobs aren’t led astray.
Super writeup!
Old Oct 20, 2009 | 12:24 PM
  #61
uweb's Avatar
C32 '02 silver 70K
Super writeup!
Old Dec 8, 2009 | 02:01 AM
  #62
NamC32's Avatar
02 C32
Totally agree ^ i get alot information from reading this threat and i will read it again to see if i miss anything.
Old May 31, 2010 | 02:34 PM
  #63
alkrstev's Avatar
Silver 02 C32 & White 05 CLK500
My car was making some strange squeaky noises from the engine. So, I thought it might be the belt since my STOCK 02 C32 has 72k on it. However, before I ordered the belt, I did some research and found this thread. All of the symptoms I had led me to believe that it was not the belt. I took off the belt and spun by hand the guide pulley (next to the sc pulley) and the one right underneath it, the Idler Pulley. The guide pulley was fine as it was already replaced once. Needless to say, as soon as I spun it, the idler pulley was rattling very badly and when I took it off and shook it, it sounded like there was something loose and rattling in it. I immediately ordered a new idler pulley and put it on my car. Now the engine is much smoother and without any noises. I am dreading thinking of how much money would have to be spent if it seized and broke off from the housing. THANK YOU VERY MUCH BOOHOORAMBLERS for this thread and for saving me a lot of money and I hope others will also benefit from this thread.
Old Dec 15, 2010 | 07:28 PM
  #64
AMG_Freak's Avatar
C32 AMG
Clarification please.
Definitely a great write up! Can anyone tell me if there's a sound delay in this video - specifically at 1:50 into the video. I'm having a grinding sound coming from the pulley he points to at 1:55. The audio is stating this is the idler pulley, however, I think it's actually the SC pulley.
I've looked at the diagram but it doesn't identify any of the pulley's as Idler or Supercharger Pulley. The diagram has #5 as the Electromagnetic Clutch which I believe is actually the SC pulley. The Electromagnetic Clutch is behind the SC pulley if I recall correctly.
At any rate... Does anyone know where I can obtain the part without paying high dollar from the stealership?
Thanks!
Old Dec 15, 2010 | 11:16 PM
  #65
boohooramblers's Avatar
Not an AMG :(
Yes - for whatever reason there appears to be some type of glitch with my Photobucket videos: the original doesn't have that audio delay.
In the video link, I am indeed pointing to the SC pulley / clutch at 1:55.
Yes - #5 is the SC pulley / clutch assembly.
#4 is the pulley we refer to as the 'Idler' pulley.
If #5 is where you are hearing the noise, check out this thread - you may only require a simple bearing swap.
If you are looking to replace the entire SC clutch / pulley assembly, you are looking at some serious $$$$.
If you just need the bearing, NeedsWings offers one for about $55. Here's the link.
Old Dec 16, 2010 | 08:52 AM
  #66
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Hey boohoo.
I am glad to see that you still post your valuable thoughts and comments here. I have been a bit depressed since you sold your rig and shoved off to school. I hope all is going well for you.
Unfortunately, Code3's old video in that link is dead. I'm about to do that bearing swap myself and could have used that for my change out.
Old Dec 16, 2010 | 11:20 AM
  #67
Not an AMG :(
Originally Posted by ScottW911
Hey boohoo.
Hey Scott! Yes - school is going well. I miss my C32 terribly
Just checked Code3's thread - pity the video is dead. In any case, the bearing replacement is fairly straightforward as long as you have a vice (if not a press).
Just in case you haven't replaced this bearing before, be very careful removing the clip - it can fly off the ends of the pliers and disappear! Suggest you put some tape over the end of the pulley to catch the clip in case it decides to 'travel'!
Re: getting the old bearing out and the new bearing in, a good bench vice will suffice - just make sure you have a block of wood or something that is a good fit over the diameter of the bearing as you don't want unequal load on either side.
You will probably already know this, but you can make life easier on yourself by using the cold weather to your advantage: put the bearing outside to cool and have the rest of the pulley / clutch at room temperature or warmer. The contraction / expansion (however small it is) will help ever so slightly!
Old Dec 16, 2010 | 02:17 PM
  #68
AMG_Freak's Avatar
C32 AMG
Thanks for the clarification and the link to other information. Sorry to hear about you missing your old ride. Hopefully, my car will sound like it should after I replace the bearings.
Old Dec 16, 2010 | 03:26 PM
  #69
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
def good write up! all the videos are not working
Old Dec 16, 2010 | 03:47 PM
  #70
ScottW911's Avatar
Dang. You have got to have more street sense about this stuff than anyone I've met. You will make a great doctor. Best wishes to you and your bride.
Old Dec 16, 2010 | 03:49 PM
  #71
AMG_Freak's Avatar
C32 AMG
I think it may have something to do with Rambler's photobucket account. The video is working in my post on 12/15 @ 6:28pm
Here's the other one:
Old Dec 16, 2010 | 04:10 PM
  #72
AMG_Freak's Avatar
C32 AMG
Not sure why the video above is not working correctly.
Here's the direct link:
http://s265.photobucket.com/albums/i...rSpin_0001.mp4
I know it works - I'm watching right now.
Old Dec 16, 2010 | 10:06 PM
  #73
gtr886's Avatar
E63 W211 08, C32 W203 02
I'm planning to change my SC oil and change the pulleys at the same time.
I understand that Pulley 4&9 is the same part 112 202 01 19.
What about the part number for #6?
The pulley #4 is 15lb torque, What about the #6 and #9? is it that same as well?
Thx in advance
Old Jan 5, 2011 | 12:39 PM
  #74
Not an AMG :(
What about the part number for #6?....
#6 is the supercharger guide pulley.
The part number for #6 is 1202000470.
Bear in mind that although the tensioner (#9) and guide / idler (#4) pulley may be similar, the intent is that you replace the entire tensioner assembly (for obvious reasons).
The part number for the tensioner assembly + pulley is 1122001070.
....The pulley #4 is 15lb torque, What about the #6 and #9? is it that same as well?....
The torque value for the supercharger guide pulley (#6) is the same as for the idler pulley (i.e. 20 Nm or ~15 ft lb.).
Note that a torque value is not given for the tensioner pulley (#9), because (again), the intent is for the entire tensioner unit to be replaced.
IMPORTANT: Due to the low torque values involved, please ensure that you use Loctite (or the equivalent) thread locker.
Old Jan 15, 2011 | 07:30 PM
  #75
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Replaced mine today…it’s now much quieter.
Greetings from your friends in the States.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
