Replaced SC Clutch bearing last night ~ pics/video
Before & After Video
Looks like those 20 dollar bearings I bought will get changed every 30K miles.
Three questions for you:
1. Is it absolutely necessary to have a press? I don't have one, and I guess I could go to a local shop and get them to remove the old bearing and press in the new one.
2. Did you just grip the pulley with a leather glove to undo that bolt in the front, or is there somewhere you can put a mandrel in to stop the rotation?
3. What did you clean the pulley with before you replaced it? It looks much better afterwards.
Regards,
Pete
Regards,
Pete
2. I used air tools, and a slight grip. You could also lodge something between the clutch and the block.
3. I did clean the pulley. If I have something off the car already, it always gets cleaned up
I used Throttle Body Cleaner to get the oil and dirt off, and a small wire brush to get any of the hard crap off. It cleaned up real nice.
its the best $18 i have spent in a long time...
to think that the dealer wanted $1k for a new s/c clutch is a crime!!!!!
i paid $70 to have mine installed, since I didn't have the press, but if you can borrow one its very easy.
What's worse is that it gives the car a bad reputation to turn a $100 repair into a $3,000 repair.
By the way, after driving for two days, the car is definately quieter than before. It also feels like the SC is kicking in when it should all the time.
110k
But I have to say, this car is so strong. Since I have bought it, I have taken care of many of the common issues. I think this engine has a lot left in it. I am the second owner. It was originally a lease from MB, with all service performed by them.
I have to admit though, as much as I love it, I am looking for an E55 right now. The prices are too good, and I could use more room for the family. More power never hurts either
That is where I purchased it from. TopGun32 will hopefully chime in with the part number as I cant find it anywhere.
this is the info I found.
there was a long thread with all the info.. but I can't find it anymore.
use houston bearings.. it will take a few days but they are good
DAC32550023
You only need one. $17.88 each
Here is the direct link:
http://www.houstonbearing.com/defaul...de=DAC32550023
btw, notice there's a C ring type of clip on the old bearing, how did you remove that part?
