18 in. Moven dual spoke w/H&R
Subscribe
Jan 12, 2003 | 10:24 PM
1st
Reply 0
Jan 12, 2003 | 10:27 PM
2nd
Reply 0
Jan 12, 2003 | 10:28 PM
3rd
Reply 0
Jan 12, 2003 | 10:29 PM
nt
Reply 0
Jan 13, 2003 | 01:00 AM
Very nice setup, congratulations!
Do you have the set of H&R Springs or the coilovers?
Reply 0
Jan 13, 2003 | 08:41 AM
NICE!!! Good looking rims you got there. How heavy are these? Oh, I like the painted caliper, nice job.
Reply 0
Jan 13, 2003 | 09:32 AM
I love those. $?
Reply 0
Jan 13, 2003 | 09:44 AM
Nice! What kind of setup do you have suspension wise? Also what's the width and offset on those wheels??
Thanks!
Reply 0
Explore
Jan 13, 2003 | 10:34 AM
Those look very nice, where did you get those and how much??
Reply 0
Jan 13, 2003 | 12:30 PM
got them at The Wheel Supply in walnut. only 208 each. not bad
18x 8.5 35mm offset
3mm front spacer.
i think they are 28 lbs. you have to call the store to double check.
H&R springs only.
tires: 255 rear 225 front
Reply 0
Jan 13, 2003 | 12:39 PM
Cool irvine! You prolly dealt with Sander right there right? He's a cool guy. They have a pretty good mechanic too!
Reply 0
Jan 13, 2003 | 12:42 PM
yeah, good bunch of guys.
Reply 0
Jan 13, 2003 | 01:41 PM
Excellent setup !!! Your car looks awesome!
Reply 0
Jan 13, 2003 | 02:39 PM
Quote:
18x 8.5 35mm offset
3mm front spacer.
H&R springs only.
Looks Great. Information on 3mm spacer - Who makes it? Being so small are they really Hub-Centric? I need a 4mm spacer. Thanks.
Reply 0
Jan 13, 2003 | 04:09 PM
unfortunately, it is a little tricky to have a hub-centric spacer smaller than 8mm. i learned the hard way.
first, your hub sticks out about 8mm. so in order for them to be hub-centric, you have to go beyond that 8mm, before you taper back to the hub size. that is why you mostly see 10mm + spacer for our cars.
my car was an early production c32, from what i have been told, other c32 front hubs are not like mine. no amount of pounding will get a spacer such as H&R on my front hub. rears will fit. my front hub does not tapper at all and sticks out about 25mm+?
so, for my previous wheels (lm5 replicas), i had a bigger hole bored into the front wheels and a hub-centric spacer made for the bigger bored hole. that worked out well, but now those wheels cannot be used without spacers (unless you want some vibration). in retrospect, i don't think i needed to do that since my hub extended so far.
so in my case, a 3mm non-hub-centric is probably fine, since the wheels still sits nicely on the hub.
having said that, there are some wheels (lorinser lm-5) that would either require and hub-centric spacer or a centering ring. this is my assumption since i originally purchased lorinser spacers for my car. they fit over the hub perfectly, but hub-centric wheels will not fit on the spacer! the spacer hub was too big. so i assume that lorinser wheels have center bores that are a little larger than the stock hub. so i think this is the case when you hear about 4mm hub-centric spacers. they are probably made specifically for their respective wheels.
anyone can feel free to correct me if i am wrong, this is only my unprofessional experience.
so, i think you may be ok if you hub extends far enough that your wheels still sit solidly on the hub.
next time i take my wheels off, i will take pictures as an example.
Reply 0
Jan 13, 2003 | 05:06 PM
VERY NICE!
I take those are the replicas. Where are they made?
Reply 0
Jan 26, 2003 | 09:13 PM
very nice!!!!!!
how much do stock c32 rims weigh if those moven are 28lbs..
Reply 0
Jan 26, 2003 | 09:17 PM
I like it! Clean look.
Reply 0
Jan 27, 2003 | 04:45 PM
They look so similar to the Style IV 2-pc. But they are actually one piece wheels, are they?
Are you using S-03? How do you like it?????
Reply 0
Jan 27, 2003 | 10:54 PM
one piece wheel.
i don't have anything to compare the so3's to. the only other tire i had were the 17 inch pilot sports. comparing a 17 to an 18 would not be appropriate. having said that, i don't have any complaints about the tires or the wheels.
i hate the ride though. way too rough. i may switch the springs back to stock, or maybe just the rear springs back to stock.
Reply 0
Jan 28, 2003 | 07:42 AM
Did you change the shocks? The springs alone doesn't give you a rough ride. If you changed your shocks to adjustables, they will make the ride rougher, unless you leave them in the softest setting.
Reply 0
Feb 3, 2003 | 03:19 PM
Your car looks dope. Do they make those wheels in 19"?
I love the red callipers, what did you paint them with, Do you have to take them off??
-PS oh ya and are you experiencing any rubbing issues??
Reply 0
Feb 3, 2003 | 04:40 PM
no, only 18's
painted with engine paint. only have to take of the wheels, not the calipers.
no rubbing.
Reply 0
Subscribe
Currently Active Users (1)
