Alignment Question
Old Dec 11, 2008 | 02:25 AM
jknust's Avatar
Question Alignment Question
Fellow MB experts...
Does the attached alignment look right? The area I am unsure about Front Axle, Track Diff Angle +/-
Target Data: -1 deg 40 +/1 0 deg 30
right wheel lock 20 deg -1 deg 43 before, -1 deg 45 after
left wheel lock 20 deg -1 deg 59 before, -2 deg 12 after
It is bold on the form, for the after correction portion... does this mean it is out of spec?? This is the only value on the form like this.
Thanks in advance.
File Type: pdf
Old Dec 11, 2008 | 02:42 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Are you left hand drive or right hand drive? (not sure where you are located).
The alignment looks fine, but if you're LHD then the front castor would be better the other way around, but it's close enough to be ok.
Old Dec 12, 2008 | 02:19 AM
jknust's Avatar
Thanks for the feedback - LHD, here in the states.
