FS:CM30 Johnson Pump
MBworld Guru
white and whiter
$100 pick up or plus shipping.
it's new. thought it was the pump went bad last time when the throttle pedal went dead, so bought it as a package deal from pshek along with the used HE. selling the pump since i've no use for it.
I'm very tempted, but I'm worried because of a couple reasons. I still have warranty on my car. Also, who would I have install it? Any recommendations?
03 g35 coupe...........02 c32 Sold
if you follow splinters heat exchanger diy, its pretty straight forward. I would recommend upgrading your heat exchanger while your at it, if you plan on upgrading your pulleys in the future. The whole job probably took me around 2hrs with the intercooler and heat exchanger with me not knowing what i'm doing. I was pretty much working and looking at john's directions from my iphone...
sounds like airplane
does it plug directly in to the bosch harness?
what size inlet and outlet does it have?
I will likely take it if I can easily get the harness to run it (the bosch ones are widely available etc.) and it will work for my system.
I was planning on upgrading to the bosch one from my current pump sometime soon
you can just use wire taps or barrel connectors. I used barrel connectors so later you can connect a 12v source to the pump to help bleed your system from air bubbles without having to engage the supercharger to activate the intercooler pump.
MBworld Guru
white and whiter
still for sale. scott didn't call me the other day when I told him I'll be free to meet him up during noon time, so I'll assume he is going to pass on it.
so this is up for sale again. $100 local pick up OR plus shipping.
hello! i sent you a pm and asked if you would mind to ship to Hong Kong.. please get back, thank you and good day!
02 C32 AMG sold!
WHEN Frank sells his I have (2) for sale, one is used and the other is new.
$150 + shipping. I don't want to start a new thread, don't want to waste
bandwidth...
bandwidth...
