judder / rough between 1500 rpm all clears as as power is fed... any ideas???
Old Dec 28, 2008 | 12:56 PM
garykit's Avatar
mercedes c32
Smile judder / rough between 1500 rpm all clears as as power is fed... any ideas???
i have a 2002 c32.... recentley it has developed a kind of judder not misfire... around 1500 or so rpm.. this is when the car is just cruising.. all ok as the loud pedal is pressed..... help??
Old Dec 28, 2008 | 10:23 PM
pshek's Avatar
2003 C-Class Sportcoupe
When was your last oil change?
Old Dec 29, 2008 | 12:33 AM
boohooramblers's Avatar
Not an AMG :(
Are you sure it's the motor?
Maybe it's the dreaded 'Tranny Jerk'
Old Dec 29, 2008 | 02:20 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Sounds like you're transmission is going to be full of coolant. Drain a bit out and if it's cloudly/milky then it has coolant, otherwise get what you drain off tested to check if there's coolant in it.
Old Dec 29, 2008 | 07:09 AM
garykit's Avatar
mercedes c32
Around 7-8k miles back...
Old Dec 29, 2008 | 07:12 AM
Ausmbtech's Avatar
Try and approach the dealer for assistance from MB, they may pay for some of the repair. If not get back to us for cheaper solutions.
Old Dec 29, 2008 | 07:16 AM
garykit's Avatar
mercedes c32
Hi... uh oh sounds nasty... what does this mean?
Old Dec 29, 2008 | 09:08 AM
SilverBulletAMG's Avatar
C32 AMG
Very very very common issue on our cars. You will find a million topics on this if you do a search for "jerk" or "1500 rpm".
Old Dec 29, 2008 | 02:42 PM
garykit's Avatar
mercedes c32
HEY THANKS FOR THE ADVICE.... HMMM... SOMEONE MENTIONED ABOUT A SPRINT BOOSTER.... TO HELP? WHAT IS THIS? ANY ADVICE APPRECIATED...
Old Dec 29, 2008 | 05:19 PM
EURO KNG's Avatar
03 C32 AMG
sprint booster will just increase your throttle response.
tranny jerk only happens to me when my car is cold other than that it doesn't happen to me often.
you do a search on it and you'll find the answers
Old Dec 30, 2008 | 06:11 AM
garykit's Avatar
mercedes c32
OK... thanks for the advice... will look
Old Dec 30, 2008 | 06:13 AM
EURO KNG's Avatar
03 C32 AMG
No problem
Old Dec 30, 2008 | 06:14 AM
garykit's Avatar
mercedes c32
love the rims!!! .... where do i find some of those... will they cost me an arm and a leg??
Old Dec 30, 2008 | 06:26 AM
ohlord's Avatar
Shifts are delayed
on cold start to allow for faster closed loop operation of the emissions system.That does not sound like your issue if it is happening in all gears while warmed up.
VALEO RADIATOR per above post,check your 2002 C32 and see if that brand faulty radiator is installed and if it is get Ye to the shop and hope it is not to late for the 722.6
It could be the cold weather.However if the valeo radiator is in the car,caution rules the day
Old Dec 30, 2008 | 06:36 AM
garykit's Avatar
mercedes c32
Hey thanks.... what is the 722.6??.....is it a different make rad....?
Old Jan 4, 2009 | 05:49 PM
garykit's Avatar
mercedes c32
722.6 RAD? WHAT IS IT?
got myself a prob with juddering from the transmission... someone said to get my rad changed to a 722.6.... can anyone tell me what this is??
Old Jan 4, 2009 | 06:03 PM
Not an AMG :(
OhLord was referring to the 722.6 transmission - that's what we have in the C32 AMG.
He was saying that you should change your radiator (if it's the faulty one) before your 722.6 transmission dies!
In many '02 C32's, we had a problem with 'Valeo' radiators - you should be able to find the Valeo sticker on the radiator with some searching and a flashlight.
Newer Valeos seem to be ok; however, many have not bothered with them and switched to a 'Behr' radiator instead.
There are a plethora of threads on the transmission contamination with glycol due to the faulty/leaky Valeo radiators - do a quick search and you'll get up to speed on the problem.
Old Jan 4, 2009 | 06:31 PM
garykit's Avatar
mercedes c32
Smile
Hey thanks for the speedy reply... will do more homework...
Old Apr 10, 2009 | 08:21 AM
garykit's Avatar
mercedes c32
Talking evil jerk 1500 rpm...
Hey thanks all who gave me advice on this tranny jerk issue.... changed the valeo for the behr... flushed transmission new filters.... all seems smooth and creamy now.... apart from making me £750 lighter... dam expensine uk....
Old Apr 10, 2009 | 08:46 AM
Biscuit's Avatar
'03 C32, '08 ML63
Always nice to see the end result of people in the forums being so helpful to the non-regulars of the forum. Glad to hear all is well.
Old Apr 10, 2009 | 08:53 AM
moosejaw's Avatar
none
so is the jerk gone?
Old Apr 10, 2009 | 10:49 AM
rockjock's Avatar
I DON'T COME HERE ANYMORE
congrats on the fix-I'm heading in morrow for a tranny flush and filters (got a "deal" at $290 here in MN,USA)-
Old Apr 10, 2009 | 01:12 PM
garykit's Avatar
mercedes c32
Talking good stuff
yeah i need to look in more really.... just about to order stage 2 tune and 185 pulley from let.... easy to fit? any advice appreciated?
Old Apr 10, 2009 | 01:14 PM
garykit's Avatar
mercedes c32
yes jerk gone... fingers crossed.... cos it was annoying the hell outta me....thanks
Old Apr 10, 2009 | 01:15 PM
garykit's Avatar
mercedes c32
ha you sooooo lucky thats good price... must make you feel better knowing uk is soooo dam expensive.... good luck!!!
