Hood Emblem Help
Old Jan 11, 2009 | 05:35 PM
SoCalC55's Avatar
2019 AMG C43
Hood Emblem Help
Before i buy this i just want to make sure it will fit in place of the star on the hood.
https://mbworld.org/forums/exterior-...blem-w203.html
thanks!
-Sean
Old Jan 11, 2009 | 06:59 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
ur good to go.....I am pretty sure they are universal
Old Jan 11, 2009 | 07:13 PM
boohooramblers's Avatar
Not an AMG :(
thanks!
-Sean
You need to ask him what the diameter is of the one you linked.
It will either:
A) Sit in the recess (this is what you want)
or:
B) Cover the recess. You don't want this option as it will leave a mark on the paint-work over time.
Most of the cheaper ones (plastic with the wingnut fastener) don't sit in the recess. However, this could be an exception.
Old Jan 11, 2009 | 07:15 PM
SoCalC55's Avatar
2019 AMG C43
flat hood emblem from my 05' C230k SS
Wouldnt that make it the one from the factory? Or are they different sizes for different models
Old Jan 11, 2009 | 07:33 PM
Not an AMG :(
I think he means that he used it on his '05 C230K SS. To my knowledge, no W203 came without the protruding Tristar. That part in the link is an aftermarket part - you can tell my the wingnut design. The OE MB equivalent (e.g. for the CL) and our Tristar has a very robust spring-loaded twist design to hold it in place.
Not within the W203 - AFAIK, the recess is the same size across the models in the W203.
Old Jan 13, 2009 | 06:01 PM
xplosiveg06's Avatar
Mini Cooper, M5
mine doesnt fit the recess, but when installed it looks fine
