May have hit a fatal flaw with the SC mod
Old Jan 20, 2009 | 01:12 AM
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
hooleyboy you are bad infuence.... my GF just told me not to read any of your posts anymore !!! lol good job man dont give up you can do it !!!
Old Jan 20, 2009 | 01:19 AM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
Thats OK, my lady told me not to write anymore post and to take the trash out! Then fold the clean towels!
Old Jan 20, 2009 | 08:26 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Stop, pleasse Stop it your killing me LOL
See yeah
AS the Jamican lady said to her man in bed, GO MAMN GO
Old Jan 20, 2009 | 06:04 PM
mkonei's Avatar
05 C55
love it!! nice find!! i used to have an s trim@17 lbs....weeeeeee...565 at the wheels from a 306. always liked the Novi kits as well. even though ive been away from that scene for some time, I cant see a kit like that running more than 5 grand. basic kits for Fords are like 3k i think. you could easily run 5lbs with a cast impeller, and no intercooler. run the factory injectors with a piggyback pump and an fmu, and get a custom tune. as bad as sales are right now though, thats the last thing i need to see!!
Old Jan 20, 2009 | 06:22 PM
msheredy's Avatar
MB
House of Power's Vortech kit for the clk looks nice
That looks like a much easier install than the 55K compressor. I'd suggest selling the 55K compressor and either going with the centrifugal blower or a turbo.
e240TT was successful at installing 2 turbos and is putting down some very decent numbers at .6bar [8.7 lbs] and that is on a smaller 2.6L V6!
Old Jan 20, 2009 | 06:23 PM
hooleyboy's Avatar
C55,SL55,C63
A vortech/paxton style kit would be a cool mod for NA cars as long as the tune is good.
I just found in todays round of phone calls a w210 55 motor with 56,000 miles for $2800. Could be a great motor start a monster motor build project. I can only do one project at a time though so I will have to pass on it, as much as I want to swoop it up. If anyone is interested I can tell you were it is.
Old Jan 22, 2009 | 12:13 AM
  #32
cruzinquick's Avatar
2005 Crossfire SRT6
This vid was posted on a thread over on CF forum thought you might be interested in it.
http://www.youtube.com/watch?v=xBJQ_c3BzMM
Old Jan 22, 2009 | 12:16 AM
  #33
jturkel's Avatar
02 C32 AMG
says that video is no longer available....
Old Jan 22, 2009 | 02:41 PM
  #34
c32used's Avatar
LET C32 2002
Hooleyboy you been at this mindset for a while...keep searching its not impossible my freind
Old Jan 22, 2009 | 11:18 PM
  #35
1qikctr's Avatar
Merc power
Like the vortec kit, even comes with a Blow off valve too.
Old Jan 26, 2009 | 09:20 AM
  #36
dwightlooi's Avatar
2005 C55 AMG
You CAN use a self-contained supercharger (like the Pro-Chargers). This is both good and bad. It is good because you don't have to drill and tap the oil pan -- which isn't really a big feat given the scope of all the work needed to install a blower. Making and fitting bracketry is way more tricky. The gear oil in the supercharger fill is better for high speed gear lubrication than typical engine oil with its motor oil viscousities and its rather dirty state. Also, you are not moving hot oil to the blower which then heats it up further than it has to be -- although the amount of heat transfer to the air charge is immaterial given the fraction of a second that the air spends going through the blower. It is bad because the oil needs to be replaced separately (every 6K or so) and is a pain in the butt to drain and fill with the blower installed and the belt and bracketry in the way.
BTW, you DO NOT have to use 0W-40 in the M113 engines. The engine can use 5W-30 and 0W30 too and some of these are listed as acceptable fills in the manual. If you are looking for the last few hp, I recommend using the lightest oil you can find. Although the Mobil 1 Advanced Fuel Economy 0W-30 is not listed as MB229.5 it won't cause your motor to fail and I find it very hard to believe that it'll be any better or worse than Valvoline 0W-30 which is listed in the manual. 0W-20 will give even more power! However, we are talking about 3~8 hp here and its not a lot given the 300+ hp nature of the engine. So, I don't know it going overboard with reducing oil drag is worth it.
Have you ever considered buying a (complete) used E55 Kompressor motor along with its ECU?
