C 320 with brabus 3.8s engine
Old 01-24-2009, 08:24 AM
ali saklaoui's Avatar
C32AMG.335 e92 fbo.protomotive996 gt2
i installed the BRABUS 3.8s engine with all electronics in my c320(2001).i will post the pictures very soon
Old 01-24-2009, 12:19 PM
boohooramblers's Avatar
Not an AMG :(
Absolutely - lets have some photos.
"There is no replacement for displacement"!
I wonder if this is similar to the 3.8L stroker motor that RennTech had available for the M112 320 motor.
I'd love to see this be a viable option for the M112K; however, the main problem is that the supercharger would be over its limit with this conversion and we would also have to change the pistons to lower the compression ratio.
Old 01-24-2009, 02:45 PM
jturkel's Avatar
02 C32 AMG
I remember reading about this a while ago.....and the price it said online was at least 5800 if not more to bore it out from a 3.2 to a 3.7 or 3.8
Old 01-24-2009, 03:02 PM
MBworld Guru
FrankW's Avatar
white and whiter
that was just the price for the motor along. no labor and other stuff. a complete car was around the same price as a C32 back then. you think it's crazy, but there's at least one complete car in SoCal.
waiting for pics
Old 01-24-2009, 03:07 PM
MBworld Guru
FrankW's Avatar
white and whiter
brabus has a 3.7L engine upgrade on the 32 which requires an engine swap. they give you a new engine and take the old one. don't see how it'll affect supercharger tho other than re-fuel mapping.
Old 01-24-2009, 03:12 PM
cost
I bought all pieces:engine+transmission+2control units(ME+EGS)and the dash board for 5000$(used)
Old 01-24-2009, 03:30 PM
CLK FAN's Avatar
2000 CLK 3.2
love the mod....
do they take your engine and bore it out or give you one all set?
and how long was the turn around?
Old 01-24-2009, 04:08 PM
i bought the parts from a local junk yard and still have all my stock parts.i installed everything in my workshop(Autodynamics garage)
Old 01-24-2009, 04:51 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
I remember reading this in Mercedes Enthusiast back in the day. I think they were around 300hp 300tq.
Old 01-24-2009, 05:34 PM
Not an AMG :(
Apologies to Ali for hijacking his thread!
Good point Frank; here's my reasoning (or lack thereof!):
For the M112K, you end up with a total displacement of 3.7L and a net gain of 50 horsepower (354 to 404 hp - a whopping 14% increase in horsepower)! To my knowledge, the OE supercharger is retained.
Although we are dealing with two different beasts here (M112 vs M112K) and slightly increased displacement (3.7 vs 3.8), if one considers the gains obtained from the N/A M112 3.2 - 3.8S conversion (215 - 300 hp for a 40% increase in horsepower), it would point to at least one (probably more) system being limiting in the M112K:
I would contend that our stock supercharger is one such limiting factor:
Our OE superchargers have a displacement of 1.6 L. What would be the gain on a 3.7 L stroker motor if a larger displacement supercharger were used? For example, perhaps the gains would be greater if a 2.3 L or 2.6 L supercharger were used? If for nothing else, one would expect the efficiency of a larger displacement supercharger to be advantageous. At least, that's how I would expect the supercharger P/V plot to behave given the increased displacement of the 3.7L engine.
Then, let's assume that one was not satisfied after shelling out more than $10K for a 50 hp gain (e.g. me!):
You would want to add intake and overdrive pulley modifications. I would say that would definitely push the stock supercharger over the limit in terms of efficiency (i.e. volume and temperature of the charged air). Certainly, laws pertaining to the adiabatic process will dictate the efficiency.
[Of course, I'm assuming that the engine internals post-conversion are up to the task - i.e. pistons, crank, camshaft, valves, etc.!]
Side question: What are the new compression ratios of the 3.7L M112K and the 3.8 S M112?
Old 01-25-2009, 09:50 AM
pics as promised
enjoy
Attached Thumbnails C 320 with brabus 3.8s engine-december08-022small.jpg   C 320 with brabus 3.8s engine-december08-023-small.jpg   C 320 with brabus 3.8s engine-december08-024-small.jpg   C 320 with brabus 3.8s engine-december08-025-small.jpg   C 320 with brabus 3.8s engine-december08-026-small.jpg
Old 01-25-2009, 09:57 AM
pics continued
enjoy....
Attached Thumbnails C 320 with brabus 3.8s engine-december08-028-small.jpg   C 320 with brabus 3.8s engine-december08-029-small.jpg   C 320 with brabus 3.8s engine-december08-030-small.jpg
Old 01-25-2009, 10:10 AM
fun with my c32
haha
Old 01-25-2009, 10:44 AM
kevkranker's Avatar
C32
nice job!
Old 01-25-2009, 12:51 PM
the compression ratio of the M112k with 3.7L is 9:1
M112 3.8s 10:1
Old 01-25-2009, 12:53 PM
395 NM
Old 01-25-2009, 03:43 PM
MBworld Guru
FrankW's Avatar
white and whiter
i see what you mean. the current supercharger won't be as efficient with the larger engine, but it shouldn't be a problem. the brabus 3.7K is yielding 404ps and 476lb-ft torque using the same IHI charger. The IHI has no problem pumping out 20psi. not sure how much boost the 3.7K is running tho. my guess is it shouldn't be much different than stock 3.2's 14psi.
Old 01-25-2009, 03:44 PM
MBworld Guru
FrankW's Avatar
white and whiter
enjoy....
nice you can catch a glimps of the valve cover being red too like brabus engine should.
Old 01-25-2009, 04:03 PM
c_klasse's Avatar
c_klasse
nice , anyway you can take pictures without the airbox on?
Old 01-25-2009, 04:04 PM
kindafast's Avatar
W210 E55 & W204 C63
haha
Is that as fast as it would go? I have yet to flat out mine since the tune.
Old 01-26-2009, 02:04 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
nice!
Old 01-27-2009, 12:25 AM
OJwerks's Avatar
not stock.
now get a kleemann supercgarger ... headers .. and see what it does lol
Old 01-28-2009, 10:45 AM
c32used's Avatar
LET C32 2002
Exclamation
Can anyone post a picture of a regular V6 C320 engine in car?
Old 01-28-2009, 03:58 PM
Former Vendor of MBWorld
AMS Performance's Avatar
AMG
Very impressive that the M112 could be increased to an even larger displacement than the M104 (3.7L max). It should be quite a torquey NA 6.
Old 01-29-2009, 12:32 AM
MBworld Guru
FrankW's Avatar
white and whiter
are you for real?
the largest M112 was a 3724cc in the ML350 and S350. Brabus 3.8/3.8S is actually a 3709cc engine.
Quick Reply: C 320 with brabus 3.8s engine
