Random Intake Idea
Absolutely no way would that fit... don't waste your time jturkel. The only mod that might get you more whine would be a 178mm crank pulley - but then you're dealing with the potential "running stacked" issues we're all familiar with. Can't think of anything else that wouldn't potentially royally screw up your current set-up.
One poster suggested that the air boxes are pressurized and that could lead to some air flowing "out" thru the Code3 intake. That is highly unlikely. The only pressureization taking place is the ram air affect that pushes air into the airboxes at high speeds. My contention is that after the pressure drop across the stock air filters any time you are on the gas hard enough to be going fast there will always be a vaccum in the inlet tract until you exit the supercharger and that is all downstream from all the filters so their is no air flow going out thru the C3P intake ever. All the C3P intake does is add a 3rd filter that is ~half the size of one stock filter or approximately adds an additional 25% of extra filter surface area to draw air in thru. So only a fraction of the total intake airflow goes thru the Code3 filter while the rest goes thru the same stock filters. The net impact is about the same as if you installed larger free flowing filters in the stock location. The SC whine is just an added bonus and adds nothing to the performance of the car. But it does sound cool, lol
I think that on hot days the SL55 option is going to show more difference than it will in colder climates just because inlet air temps will remain lower. Has anybody ever been able to measure this?
Irish
Irish
