anyone have these wheels on their w203 ?
i was wondering if anyone had these wheels on their w203 . . (C32 specifically)
http://cgi.ebay.com/ebaymotors/4-NEW-18x8-5x112-Replica-Wheel-AMG-Twin-Wheels-Rims_W0QQitemZ360129686619QQcmdZViewItemQQptZMotor s_Car_Truck_Parts_Accessories?hash=item36012968661 9&_trksid=p3911.c0.m14&_trkparms=72%3A317|66%3A2|6 5%3A12|39%3A1|240%3A1318
will the offset 35 be alright for the front/back ?
i searched the picture thread and found no1 with the black ones, but alot with silver
EDIT:
for those interested
http://www.tirerack.com/wheels/Wheel...&AID=10398365&
is where you should buy (although there not black). offset seems a little bit more compatible
EDIT:
Former Vendor of MBWorld
C55,SL55,C63
I wanted to get these wheels as a cheap alternative until I could find something I wanted. I got them at discount tire for like $100 a wheel. Long story short: We tried many offsets and the wheels would not clear the front calipers. The back wheels fit fine though. Discount Tire changed there website after my situation and made then no longer available when searching under an AMG model.
35 offset will fit the back only. It will not fit the front.
Strangely enough, Some members have gotten this type of wheel to fit.
u think with 5mm spacers theyll fit (in the front)?
thats the biggest im willing to go as i dont want the front wheels outside the damn body
of course
http://store.allsprings.com/shared/S...llsprings&All=
i guess that will make it a 40mm offset correct ?
will that (40mm) clear the front . ?
they sell 3mm spacers too
will a 38mm offset fit?
C32 AMG
of course
Volvo
These almost look like the TSWs which i bought, (Not because they were cheap, just because i liked the way the looked) as TSW Don't make them anymore, i thought i was lucky to find a brand new set. 32mm In front would be the max, and thats what im running, Wouldn't go anymore than that, 35 in back will be just fine.
32mm In front on my car (TSW)
Silver 02 C32 & White 05 CLK500
03 g35 coupe...........02 c32 Sold
a 40mm offset won't work on 18's. you need at least 30mm front depending on the design of the rim and a preferable 30mm rear. You should PM frankw about the offsets.
I'm running a 27 offset front and a 30 rear on 19x8's and the front barely sticks out. You can probably get away with just 5mm hubcentric spacers assuming your gonna get 18x8's all around and not go with a staggereed setup.
C55,SL55,C63
I for one have never used spacers. However I have some friends that have used spacers on mercedes (sclass w220 and clk500 w209) Both of them had spacers on the front wheels and they both had very bad things to say about over all driveability with spacers on the front wheels.
My friends clk500 looks abit funny too, as the front wheels stick out abit further than the back wheels.
damn . oh well i guess. ill just search around some more . i def dont want them to stick out at all basically lol
as for ppl that are gonna buy these, the seller also has 19x8, and all rims are 150+ Free shipping .
so you could order 2 of the 19's and 2 of the 18's if u wanted, and itll still be $600 . . .
(for the ppl that like staggered ^^ - including me)
http://www.tirerack.com/wheels/Wheel...985325112SATML
found these. prolly what i get
first i gotta get my C32!
those will fiit right
MBworld Guru
white and whiter
18x8 ET35 "should" fit over the AMG brakes. however it depends on how thick the spoke and how big the lip is on the actual wheel. If they can't guarantee fitment from discount tires do not buy them unless you can return them if they don't fit.
adding spacers makes the offset number SMALLER, not bigger. ET35 with a 5mm spacer makes the offset ET30 not ET40.
all the above info can be found in the "aftermarket wheel thread" in the W203 section.
1 Post
2005 C55 AMG, 2010 VW GTI (Stage 1)
