Installing Xenons
Old Feb 19, 2009 | 11:04 PM
kindafast's Avatar
W210 E55 & W204 C63
Installing Xenons
Do you guys know if there are any leveling adjustments that need to be made when installing xenons onto a c32 that has HID from the factory?
Does the auto adjusting deature work? Does the ECU reset when they turn xenon to present?
Also how much would a dealer charge for such a replacement, if I provide the lights?
Thank you in advance!
Old Feb 19, 2009 | 11:11 PM
greasybenz's Avatar
W203 C32 AMG, W124 E300D
Im a bit confused by your question. When you say installing xenons to HID do you mean replacing the frosted HID lenses to Bi-xenon lenses?
HID and xenon are essentially the same type of light. Xenon is the light that is produced in the bulb which is a High intensity discharge (HID) lamp.
Old Feb 19, 2009 | 11:20 PM
kindafast's Avatar
W210 E55 & W204 C63
Wait what are you saying..?
My car came stock with HID's. I bought a used pair of oem C32 Xenon headlights aka "frosty".
Old Feb 19, 2009 | 11:23 PM
greasybenz's Avatar
lol i think weve confused each other a bit.
So your car came stock with frosted HID headlamps and you bought another set correct?
Old Feb 19, 2009 | 11:30 PM
1qikctr's Avatar
Merc power
^^ i think he replace his frosty with another set of frosty.
kindafast's Avatar
W210 E55 & W204 C63
I am so sorry
My car came with halogens stock and I got frosties... I am 0 when it comes to lighting or electirical
Hope that clears it up.
Old Feb 19, 2009 | 11:39 PM
greasybenz's Avatar
Ahhh ok that makes sense now!
Well if im not mistaken the OEM HID's are vacuum controlled for the auto adjust. But i know when you put the HID lamps in youll have to have the dealer program the ECU to accept the HID headlights otherwise youll get a warning on your dash.
As far as cost maybe someone else will chime in on that.
Old Feb 20, 2009 | 04:36 AM
dkflipse's Avatar
C32 AMG
Out of curiosity why would you replace with frosty's anyway??
Old Feb 20, 2009 | 12:34 PM
OverDrive's Avatar
Volvo
Are you replacing the Light housing with Depos or factory... The depos will need to be slightly adjusted.. Very easy... Park to a wall (Make sure your lights are facing it) then there are 2 notches on top of the light housing, One for side ways movement the other for up and down movement... adjust accordingly
Old Feb 20, 2009 | 01:57 PM
kindafast's Avatar
W210 E55 & W204 C63
They are better than halogen
Thanks!
Old Feb 20, 2009 | 05:47 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
you just need to set the car to xenon present. Some dealers do it for free if you have a good relationship with your SA, some charge. You'll need to set it to xenon present because halogens run at 55watts and hids run at 35watts. The stock ecu will think something is wrong with your head lights when it only see 35watts and turn off the head lights.
Old Feb 20, 2009 | 11:05 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
i had to pay $60 to set mine to xenon present and drive an hour and a half to get it done.. sucks living in an area where your mb stealership doesnt see any of this going on.. those techs dont know jack s*!t here..!!!
